Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
My nat is closed for xbox live, and it takes me like 15-30 minutes to find a game anywhere.
Is there anyway that i can open it without having to call anybody or should i just buy a new router instead of this ghetto netopia one.
  • Anonymous Oct 04, 2008
    Yeah, how do I log in to my router?
  • 21 Answers
Login to the router.
find where your router has nat settings.
(myns under services)
choose nat rule entry.
add the port and ip and your done :)
Posted on Feb 11, 2008
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
When im playing black oops the game on line . it kicks me out of the game and says that there are not enough players,but when im trying to start a new game , it said that i have signed off of xbox...
It sounds like this is probably an issue with your internet. Do you have problems with any other games? Are you able to browse the net completely? Are you behind a firewall?
You may have a Moderate or restricted NAT which can interfere with online gaming. If you are behind a router you can look up your make/model of router. and then go to the manufacturers website and look on there site or google and see about opening the NAT as well as maybe putting the xbox in the DMZ (De Militarized Zone, or basically meaning outside of the firewall without restrictions). Doing that should solve the issue most likely.
You may also want to test this theory by hooking up the xbox directly to your cable/dsl/fios modem without the router. If you do that make sure you power all devices off for a minute. then boot up the modem first, then the xbox.
Feb 05, 2011 | Microsoft Xbox 360 Console
Hi, I have a Dir-600. I'm trying to have Open NAT on this, cause I want to play Xbox live without any trouble. I have opened ports 87-89 UDP, 3073-3075 UDP and TCP. I assigned these ports to my Xbox...
NAT STRICT
Step 1 : Connect Router - Computer ( Wired )
Step 2 : Open Router setup by typing http://192.168.0.1 on the address bar of the internet explorer
Step 3 : The Default Password is admin
Step 4 : At the top Click Advanced
Step 5 : On the left Click Firewall Settings
Step 6 : Enable DMZ
Step 7 : give the IP Address of the Xbox/PS3/Wii in it
Step 8 : Uncheck the option Enable SPI
Step 9 : Click Save Settings
Step 10 : Test the connection
let me know if this works
Regards
TOM
Sep 20, 2010 | D-Link DIR-600 Router
Xbox Console: when i sign into xbox live to play cod mw2 when ...
you NAT type is most likely not open.
Without and open NAT, you xbox live connection will not be as efficient.
I have a tip on my page with detailed instructions on how to open you NAT.
May 18, 2010 | Microsoft Xbox Console
Xbox nat setting
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Mar 07, 2010 | Microsoft Xbox 360 Controller
XBOX 360 strict NAT problem
Make sure you also open the ports on your router. IF you have all the appropriate ports open and still have strict NAT, it's more than likely your ISP and you should give them a call.
Jan 07, 2010 | Microsoft Xbox 360 Elite Console - Black
Change NAT to open
You need to open all the ports for the xbox live. The NAT of that router model cannot be configured to open. Its just a simple NAT for internet connection.
Feb 09, 2009 | Linksys WRT160N Wireless Router
Nat / strict
First, why are you connecting to your laptop? Second, reset your modem and router. I doubt you need to open ports that are not normally open...but if you think you need to do more, access the router and open the ports manually.
Nov 27, 2007 | Microsoft Xbox 360 Console
Nat settings on netgear wgr614 wireless router
Hello --
Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
Oct 15, 2007 | NetGear WGR614 Wireless Router
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
1,303 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Elise Lacoursiere
Elise Lacoursiere
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
