Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Problem hi team i have a problem when i try to add a printer the following mesage coming on the window "Windows cannot connect to the printer.Either the printer was typed incorrectly,or the specified printer has lost its connection to the server." . this is the problem plese help me thanking you Yoursfaithfully yaz
  • Silviu Bucsa May 11, 2010
    how do you connect your printer to the pc - usb / lan / direct connection? does it use a printserver like fiery? what type of drivers do you use?
How to lock machine,
and How to unlock the machine.
my email id is prashanthmbs@yahoomail.com
Posted on Mar 06, 2008
I need driver for hp 900 inkjet that will install in windows home basic
To install HP 900 inkjet printer hare is the following step you need follow.
1. Connect you printer with computer and printer should be on.
2. open devices and printers form start and select add a printer,In The Add Printer Pop Up Wizard, Select Add Local Printer and click on next
3.In the Use an existing port drop-down list, select USB Virtual Printer Port (Printer Port) and then click next.
4.Under Manufacturer List Select HP
From Printers List, check whether your printer is listed.
(If your printer is listed there are inbuilt drivers available for your printer in windows 7, if not you can try clicking on the windows update button to get more manufacturers and more printer models, or if you have a disc of your printer drivers you can use have disk option and point to that)
Click On next.
5. In the Printer name text box, type the printer name( leave the default printer name) and then click Next. The printer driver starts to install.
you can also install printer driver with windows update. windows update automatically install your printer driver.
Jun 05, 2012 | HP 900 Inkjet Printer
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
I want to be able to print on a Epson FX 890 printer installed on a windows computer through network from my mac osx computer
If your printer is attached on the network ..follow these ..for to add it as default printer..
(you may install its driver first ..just in case..cause on the network it may have the windows drivers..)
http://docs.info.apple.com/article.html?path=Mac/10.5/en/9031.html
If it is attached on the computer alone ..but the computer connected to the network ..you may try to connect to the printer and if it do not find it ...you will have to select to share the printer in that other computer ..
Another simple way to use it ..its just to send the job to the other computer and print it from there ..You can even use a team viewer to do that ..It is a free (for personal use only ) ..and make a connection to that computer which will allow you to transfer the file easy and fast ..and have control to that computers desktop ..
read more about here ..
http://www.teamviewer.com/en/index.aspx
Aug 09, 2011 | Epson FX 890 Matrix Printer
I do not know how to install my HP PSC 2410xi model in my windows 7 OS laptop. I tried the windows update but it does not have the PSC 2000 series, it only has PSC 2100 and up. I tried installing the PSC...
Following are some of the tips, which you must follow while you are using a printer with Windows 7 system.
Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well.
Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on.
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Jan 07, 2011 | HP PSC 2410 All-In-One InkJet Printer
How do I add a printer to my laptop
At this time, a full feature Windows 7 driver solution is not available for your product.Follow these steps to install and configure the driver that is compatible with the product.
Follow these steps to install the compatible driver in Windows 7.
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers . The Devices and Printers window opens.
  3. Click Add a printer . The Add Printer window opens.
  4. Click Add a local printer .
  5. Click Use an existing port .
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port) , and then click Next .
  7. Under Manufacturer in the Install the printer driver window, click HP .
  8. Under Printers , select the Deskjet 660c and then click Next.
  9. In the message window, click Finished .
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties . The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK .And print a Test Page.
Regards,
Riztech
Jun 01, 2010 | HP DeskJet 656c InkJet Printer
Cant install my hp deskjet 3325 printer to the windows 7
Follow the below steps to install your printer in Windows 7.
  8. Under Printers , select Deskjet 3600 and then click Next .
  11. Click Close to close the window.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4 .
  15. Click OK .
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page .
Regards,
Rizwan
Jan 29, 2010 | HP DeskJet 3325 InkJet Printer
Windows Games - MISSING FILE!!!!!!!!!!!!!
u need to go to control panel , go to add remove progs , go to add components and remove games and reinstall again .
Feb 24, 2009 | Compaq Presario 700 470024-192 Notebook
File Sharing
Here’s a very short summary of how to create a home network:
1) Create a named Workgroup (computer network name).
In Windows, the defaults are MSHOME or WORKGROUP, but you can choose your own
2) Add computers to the named Workgroup
3) Enable file and/or printer sharing.
Here are some resources to help you:
1. Windows XP has a wizard to walk you through it - see tutorial here
2. For Vista, try this link for a detailed overview: http://technet.microsoft.com/en-us/library/bb727037.aspx
These links might help too:
http://www.dummies.com/how-to/content/how-to-create-a-pc-network-workgroup.html
http://www.dummies.com/how-to/content/connect-to-and-share-files-with-other-pcs-on-your-.html
3. When it comes to sharing folders, there are two main ways to do this. You can either 1) right click the folder and enable sharing through the shortcut menu., or 2) add the file/folder to ‘Shared Documents’ (for XP) or ‘Public Folder’ (for Vista).
Hope this helps, but please come back to Fixya if you have any difficulties. Good luck!
Jan 25, 2009 | Belkin (F5D8231-4) Wireless Router...
Problem
yeppers...looks like a case of the missing printer. Remove it and add again. I'm assuming it's plug and play. You should be able to browse your network for it, right?
Got backup?
Feb 10, 2008 | Office Equipment & Supplies
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
89 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
