Question about Compaq Evo D500 PC Desktop
Powersave problem i dont know what happened, i turned my computer on and a message came up on monitor screen sayin "Monitor on powersave turn off using pc" how can i fix this problem?
  • Nolan Blew
    Nolan Blew May 11, 2010
    Does the message come up right when you press the power button on your computer, when the login screen comes up or after you log in? Also, is it a message box that the system is giving you or is it a message that the monitor itself is giving you (like when it says No Signal Detected, etc)?
  • 407 Answers
Hi   if your system is run.........you go to control panel press power
options then press
1. always on
2.turn off monitor never then press apply .ok & restart your pc.....
 if your pc is not start your UPS some error...
change it.....BU..OR Battery..
 best of luck.....
Posted on Feb 10, 2008
If you are using a desktop computer, chances are that you don't want the computer to go to sleep automatically. This is even more the case if you are running Vista in a virtual machine for testing purposes.
Disabling power management is simple and easy. First go to the start menu and click on the Control Panel.
Click on the System and Maintenance link
Then click on the Power Options link:
It will disable automatic sleep mode, but will still turn off display.\
You can click on change plan to disable.
If you are using XP than.
Open control pannel-> click on power option -> keep turn off monitor setting to never.
EVERY TIME I TURN MY MONITOR ON IT SAYS "GOING TO SLEEP" AND THEN THEN SCREEN GOES BLACK! BUT MY COMPUTER IS STILL RUNING. I THOUGHT IF I COULD GET A MANUAL I COULD TROUBLE SHOOT IT AND FIX IT. BUT WHEN...
its a very very old monitor,so old in fact , you PC then had no sleep modes. so its inside the monitor, this old
so push the menu key on front of monitor and turn off
sleep/powersaver. ,
no the manual is only, you do know fixya is not HP right?
nor are we COMPAQ
did you leave off works in front if the 1501, HP made types with just that 4 digits.
Compaq 1501
https://www.manualslib.com/manual/30085/Compaq-Tft-1501.html
L1501 and TFT-1501
read the service tag on the monitor and see the real full name
then post that for 10x better answers even the book.
Nov 06, 2017 | HP Compaq 1501 15" LCD Monitor
LG stuck in powersave mode
Connect it to a different computer, e.g., a notebook computer,
and set the screen-resolution to 800-by-600, and see if the monitor works.
Change the screen-resolution to 1024-by-768, and try again.
Change the screen-resolution to 1280-by-1024, and try again.
Connect a different monitor to your computer,
and set the screen-resolution to 800-by-600.
Then, disconnect the "alternate" monitor, and connect your monitor.
Nov 25, 2009 | LG W1942TQ-BF 19 inch Monitor
Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
May 09, 2009 | Dell Dimension E520 PC Desktop
LG1717S powersaving mode problem!
Have you tried to disable the pwer saving mode and see what happens. What operating system do you have on this laptop please ?
Mar 07, 2009 | Computers & Internet
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
POWERSAVE
I have A "Dell" E152FPc, and I have found an open transistor (Q201) on the Power Supply Board. My monitor comes on nice and bright for approximately 2 seconds, then goes dark; the power LED is steady. The voltage to the PWM IC is waky.
Before you try any hardware troubleshooting go to your control panel and turn off any power management options.
May 26, 2008 | Dell E171FPb 17" TFT LCD Flat Panel...
Powersave
If it's going into powersave mode, it usually means it's not getting a signal from the video card. Try plugging this monitor into another machine or laptop and you should be able to tell if that's the issue.
May 26, 2008 | Dell E171FP 17" Flat Panel LCD Monitor
URGENT Big project due...Monitor won't stay on...light goes yellow after initial message c below
check the cable which connects from the monitor to cpu is connected properly... if it s not connected properly this problem occurs.. just reconnect it ... ur problem will be solved...
Dec 03, 2007 | Sony SDM-HS73P 17" LCD Monitor
Compaq Evo D500 PC Desktop Logo
99 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
