Question about Kenmore 24 in. 17032 Built-in Dishwasher
Lds 5811ww dishwasher e1
I have the e1 error and the local repairman can not repair it. They have tried a new motherboard to no avail and have stated the problem is with the power getting to the unit. It is not 120 volt. They are wrong. I think I am on my own with this issue. Help.
The dishwasher beeps and brings up a 1E message after only a minute from the starting of dishwasher, when turn off and on again the same process happens, it won't go past this stage on any cycle .
  • Anonymous Dec 15, 2008
    i have the same problem new machine comes up with E1 message don`t know what to do
  • 423 Answers
Below are the steps recommended for 1E error code but I, too recommend you open the door panel and inspect the wiring as recommended above. For the original posters, can you add a comment about what you did to get back up and running.
The Water Supply Tap is closed.
The Water Supply is shut off.
The Inlet Hose is kinked.
The Water Pressure is very low. (below 10 psi)
Inlet Valve is OK? --Measure the electric resistance of Inlet Valve. (950-1300 oms)
The filter of Inlet Valve is clogged by impure water. --Clean the filter of Inlet Valve.
The Hall sensor is OK? --Check the frequency of Inlet Water by the Test Mode.
The Impeller of Air Guide is bound. --Replace the Air Braker.
Posted on Apr 05, 2009
  • 92 Answers
Ther is a problem with the noise insulation in the door. It damages the coating on the wires and causes them to crack that can lead to any type of problem. lg recomends replacing the inner door and the wire harness hope you have warranty!!
Posted on Feb 10, 2008
What can I do for an E1 code?
Hi liyoung,
The full description on what to do is located in my Tip below:
L.G DISHWASHER E1 ERROR...
Hope it helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it.
Jul 19, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
I get the E1 code a few minutes after I start the dishwasher. Am I able to do something or do I need a repair person?
Hi liyoung,
Hope it helps :-)
JEDEMEYER1
My dishwasher is an LG LDS 5811WW it reports an IE reading after one minute. Any help?
check clogging of water inlet hose ( or hose twist or freezing)....check water supply
Oct 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
AE displayed on LG dishwasher
Please look one more time. The LG LDS 5811 dishwasher error codes are:
IE Error
OE Error
FE Error
E1 Error
HE Error
tE Error
It would also be helpful to know what happens when this error code displays. Please post back here, OK?
Thanks.
Apr 16, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Motor removal
I am having a same problem. You can open dishwasher sump assembly from inside the dishwasher and check if something is blocking white impeller. I tried to open impeller and sheared screw head as I did't realized it is left handed screw. Even after cleaning impeller you still get problem, you need to check from bottom and see if something is stuck there. If all right and you are still getting error then it is time to replace motor. In my case I ordered entire sump assembly as my seals were also wornout. Sump assy cost $113 on Sears part direct.
Dec 30, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Lg dishwasher lds 5811st E1 error code
Hi Chaz,
The impeller breaks on the motor shaft. The motor still turns, but the impeller doesn't, so it doesn't pump water. Because the machine senses there is no water pressure from the pump, it shuts down & displays E1 (it thinks there's a water leak, due to no pressure)
Unfortunately the motor/impeller is only available as a complete assembly
Hope this helps
Col
Dec 11, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
E1 error on LG dishwasher
As per my email reply chazmano5, the problem is likely to be the water pump/motor assy.
They have a very common fault of the impeller breaking on the motor shaft. The motor still spins, but the impeller doesn't, so there is no water being pumped.
The machine senses there is no water pressure and shuts down, displaying E1 (eg: it thinks no water pressure means there must be a water leak) Unfortunately the motor/impeller is only available as a complete assembly.
Dec 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LD Dishwasher power problem
On the LDS5811 model, I doubt very much that the door switch would cause a full failure.
If you are confident the power is live into the dishwasher, the most common failure with this symptom is a failed controller card (PCB) and will require a service call to LG.
Aug 09, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
LG have a history of E1 error problems.
The controller board can be one cause, however, most of these are caused by a faulty circulation pump.
The impeller breaks on the shaft and does not turn, so it doesn't produce pressure. A pressure sensor activates, bringing up the 'E1" message.
The impeller and pump are a complete assembly.
Replacing it usually fixes the problem.
Oct 30, 2007 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore 24 in. 17032 Built-in Dishwasher Logo
277 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
