Question about HP DeskJet 845c Printer
Printer problem i wanted to print a document but then my printer doesn't work. The ink was stuck on one side. It doesn't go to the other side or it doesn't move at all. how can i fix it?
    Genius:
  • 3,587 Answers
Hmmm..you mean the cartridge carrier? Try turning off the printer(unplug from the outlet) let it rest for around 1 or 2 minutes(to discharge all the electronics) and then try again. You may have a jammed carriage assembly, from what you're saying, but sometimes it also happens when the machine hits a power speed bump too.
Got backup?
Posted on Feb 10, 2008
The document can hardly see the print on the page and it is not the ink?
Take out the ink cartridge and se if it ha ink in it. Also inpsect to see if ink has leaked out.
Nov 06, 2013 | Office Equipment & Supplies
Kodak 7250 print head jam
This problem has plagued me for a very long time. The issue is that the printer head is "glued" in the resting position under the guard of the printer, so you can't remove the ink cartridges to clean it. Solution is to (I know this sounds stupid, but it works) turn the printer on the side where the printer cartridges are (if they are stuck on the left side, turn the printer on its side so the cartridges are on the bottom). Turn the printer on, and the cartridges magically start moving! I guess there are some sensors that get tricked out when you tip the printer on its side. If the cartridges are still stuck, click the "ok" button, and before it gets a chance to see if you actually fixed the problem, turn the printer off using the power button. It takes a long time, but you should see the ink trap lower (release the ink cartridges) and the ink cartridges start moving to prepare for shutdown! Grab the cartridges when they move out of their hiding place and don't let them go back until you clean the print head so it doesn't get stuck again. Remove the ink cartridges, then push the grey tab to release the print head. Wipe the bottom of the print head clean with rubbing alcohol (it will have a lot of gooey - sticky ink stuck on the bottom). I used nail polish remover since I didn't have rubbing alcohol available. You can also wipe down the ink pad which is where the ink cartridges were previously jammed to clean up more of the mess and prevent this sort of thing happening again too soon. Good luck!
Jan 20, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
Page not printing on Canon PIXMA MP750
That's as common as rocks with inkjets, especially if Copy doesn't produce visible output. Fortunately the clean cycle gets results pretty often. You need to heed the printer humidity spec. and follow the manual's further actions for when 'Clean Head' doesn't work (typically cleaning its bedding and/or running some rubbing alcohol through via a handy empty cartridge.) See your local ink refiller if you want a friend to lean on for cleaning cartridge fiddling.
Oct 22, 2011 | Canon PIXMA MP750 All-In-One InkJet...
Ran out of ink, changed the ink and the printer prints a blank paper...checked the ink everything is good...still nothing printing??
Make sure you are inserting genuine Lexmark cartridges.
Try to re-seat the cartridges into the printer. Remove the cartridges > close the printer cover > unplug / re-plug the printer into the power source to reset it > when the printer turns on, firmly reinsert the cartridges. Try to print a document again to verify that the problem is fixed.
If that doesn't help, try to clean the print cartridge nozzles. Open the Lexmark Solution Center on your computer by going to Start menu > Programs / All Programs > Lexmark Z600 Series > Maintenance tab > Under Select a Maintenace tool, select Clean to fix horizontal streaks. > click Print. Then try to print a document again.
Sep 13, 2011 | Lexmark Z615 InkJet Printer
Dell AIO Printer 946 I can't print a word document in black and white. When i click on printing preferences, it doesn't allow me to click on " print in black and white" Please help
In printing properties have you selected the 'grayscale' option, if still not working, in printer properties select maintenance > select Ink and cartridge settings > there select "black Ink only"
Jun 01, 2011 | Dell AIO Printer 946
Does the Lexmark X9575 print automaticly 2 sided with no manual feed. I have a 15 page document doulbe sided. How do I print this without babysitting the printer. Thank you
Your model supports automatic duplex printing using letter and A4 sizes ONLY. If you want to print two-sided documents on another type or size of paper, use the manual duplexing method.
1) With a document open, click "File" > "Print..."
2) Click "Properties" or "Preferences" or "Options" or "Setup" depending on your system
3) Click the "Advanced" tab
4) From the "2-Sided Printing" area, select the 2-Sided Printing option and then select either the "Sideflip" or "Topflip" option (sideflip is the setting most often used)
5) From the drop-down box, select Automatic.
6) You will see an "Extend dry time" option, which allows extra drying time between sides when you are printing on both sides of the paper. The Automatic 2-Sided Printing option affords enough time for the ink to dry on supported paper types in average air humidity. Under conditions of high humidity, or if the normal drying time does not allow the ink to dry completely, you should select Extend dry time.
7) Click <OK> to close any printer software dialogs that are open. This will take you back to the General Print screen.
8) Click "Print"
Note: To return to single-sided printing, return to the Advanced tab. From the 2-Sided Printing area, clear the 2-Sided Printing check box.
Jan 14, 2010 | Lexmark X9575 InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
HP DeskJet 845c Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
