Question about Durabrand DUR7 Portable DVD Player
Durabrand DUR-7 portable DVD player
When we put in a DVD it says no valid disc.
  • 2 more comments
  • THESTARRIDER Feb 12, 2008
    My DRR-7 DVD player says NO VALID DISK when I put in a disk that is
    known to be good,it works in all of my other DVDplayers.I have
    tried several dvd disks and get the same error.
  • dslrealtor Apr 15, 2008
    This must be an issue, I have the same problem.
    It WILL play an audio cd, but put a dvd in & "no valid disc"
    I have cleaned the lens.
  • Anonymous Aug 29, 2008
    I put a know to be good dvd in and it says no valid disc.
  • tyronegullet Sep 01, 2008
    when we push play on dvd player it flashes no valid disc. no steps have been takin
    Brigadier General:
  • 6,966 Answers
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 10, 2008
SOURCE:
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
When I put the disc in it starts to load and tehn a messagE " NO VALID DISC"
Maybe the file format is not supported or the disc might be in bad condition. Try using lens cleaning disc.
Nov 06, 2009 | Toshiba SD-3980 DVD Player
Disc not valid messge
yo may want to try cleaning the lens and you might also try cleaning or repairing disc an/or lens
Jun 03, 2009 | kawasaki PVS32801 Portable DVD Player
Dvd-cdrom plays music-cd.Not dvd-cd :No Valide Drive/Disc Found
Simply change the ROM to DVD RW drive since this is an old PC and now days nobody uses a dvd rom but a dvd writer. It will be worth it since it can do all the functions and is also more hardy........sodeep
Apr 29, 2009 | Compaq Presario 7599 (173952-004) PC...
No valid disc
your not using a good disc. use a regular disc and no blue rays
Mar 31, 2009 | GPX D1816 DVD Player
MPIO dvd player reads "no valid disc"
Try cleaning the lens with a dab of rubbing alchohol and a q-tip. If error continues, throw unit in garbage.
Mar 02, 2009 | Televison & Video
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
DVD will not come out
Believe it or not, unplug the power from the wall for at least 60 seconds. Then plug back in and power up the unit and eject the DVD. Sometimes you need to do this 3 times before it works. My complaint is that I need to do this for 95% of the DVD's I insert and then try to eject. This is clearly a manufacturer's defect...
Feb 17, 2008 | Toshiba 19HLV87 19 in. LCD HDTV
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
193 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
