Question about RCA F27442 27" TV
Channel Changing Problem
When I try to manually turn the channel the station number changes in the upper right hand corner but the tv stays on the same station. The remote control has all features working except the channel changing. HELP
  • Alex411 Feb 10, 2008
    Pefect!!! thank you
  • 84 Answers
You have to go through the set up guide and reset the information you put in. It may have changed. Afterwards you must run through the auto program. This is a common problem i find with customers.
C-Dog
Posted on Feb 10, 2008
TV Flashing from Channel to Channel Non-Stop. Problem with the RCA F32689 32" TV My TV started jumping from channel to channel non-stop. There's no picture or sound - only channel numbers changing...
If still under guarantee take it back.
If not this sounds like a workshop job. If more than five years old (the TV, not you!) and you can afford it, junk this set and get a new one.
Sep 21, 2011 | RCA F32689 32" TV
I was given an older Sony TV Model KV-27510. It works fine but when watching TV, the Channel number stays on in the upper right corner of the screen. (in this case #3 since I have cable) When watching a...
some tvs are set to hotel mode if they were bought for this and can have the channel number on all the time , you may be able to remove this using this manual. https://docs.sony.com/release/KV27S10.PDF it may help you to read this to remove it.
Jun 30, 2017 | Sony Televison & Video
Screen is all snow and channel 4 shows in the upper right hand corner. TV needs to be on channel 3, but trying to change it manually does not work; therefore, satellite tv does not work. I've checked...
Check your TVs settings. Check if channel skip option in on. If it is on, this type of fault occur. Turn it to off if it is in on condition. If the blue back screen option is there, just turn it on to avoid grains on unused channels.
Oct 13, 2010 | RCA F32649 32" TV
Displaying TV Channel Numbers clearly
Hello jdillion,
I do not believe that such a device exists, however I do have some options for you:
1) get a magnifying window to put in the corner where the number is to magnify that section for your father.
2) Have TV repair shop install a signal to voice converter to take the number generated signal and convert it to a voice so that way the changing of the channel will be heard as a voice as opposed to a number.
3) Have the number geometry changed by a TV repair shop with the ability to reprogram the EEPROM that controls the number generation circuit.
I hope these suggestions give you some idea of what is possible.
Thank you,
Shuttle83
Oct 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Can not remove the number of the tv channel from the screen
How to remove the green number three from the right corner of the tv screen without having the original remote as the cable company suggested.
Dec 12, 2007 | Televison & Video
Channel numbers scrolling
the tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Nov 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony kv-32s42 needs help.Tuner problems?
Hi Grasshoppa, I would venture a guess that your tuner is not at fault but most probably the logic circuits controlling it since as you posted, you can tune > get a good picture but "channel numbers in the upper right hand corner ...." If your intention is to use the VCR and thereafter change channel using the VCR, you may use the Audio/Video input. With an RCA 3 cable connector, connect the (Yellow) Video out, (Red/White) L/R Audio out of the VCR to the Video in &L/R Audio in of the TV. You don't need to set the TV to Ch 3 but rather select Video 1 or 2 or A/V. Hope this be of some help/idea to you. Post back how things are or should you need further information. Good luck and kind regards
Jul 27, 2007 | Sony KV-32S42 32" TV
Cluster of stuck pixels
sounds like its stuck in another mode. Do you have the original remote to sdee if you can switch off the display section or the closed caption?? good Luck
Jul 28, 2006 | Toshiba 20AF43 20" TV
RCA F27442 27" TV Logo
73 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
