Question about NEC VT460 Multimedia Projector
Lamp will not come on
Has anyone ever run into this problem before? I have a VT46 NEC Projector When I turn the power switch on the back of the unit, the power light on the top of the unit is orange, when I press the on/stand-by button on top the power light is steady green, fan comes on.
Within about 10 seconds then status light starts blinking green, for about 10 seconds then goes out for 5 seconds and comes back on a second time then fan kicks in high, the status light turns red and power light is now blinking orange for about 30 seconds and fan shuts off. Status light continues to blink in increments of 6 blinks over and over again power light remains steady orange.
The lamp light on the top of the unit NEVER lights up at all.
Lamp never lights up, I tried a different bulb projector does the same thing.
…and I do not have the remote anymore the person who used the projector when it last worked also lost the remote!!!
Can anyone help?
Ron
  • 3 more comments
  • Anonymous Mar 16, 2008
    I have the same problem as DrRon only the reset doesn't work. When I power on the projector it tries to light the lamp twice and then gives the same status with the Status light blinking six times. I tried to reset but it did not work.
  • mymao Oct 03, 2008
    I have the same issue. I tried to press the enter button for a bit more than 30 seconds and nothing happened.Who can sort this out for me ?
  • Anonymous Oct 23, 2008
    "Within about 10 seconds then status light starts blinking green, for about 10 seconds then goes out for 5 seconds and comes back on a second time then fan kicks in high, the status light turns red and power light is now blinking orange for about 30 seconds and fan shuts off. Status light continues to blink in increments of 6 blinks over and over again power light remains steady orange."
    I have the same problem with mine. I tried holding in the enter button for 30s (and more) and got no response from the projector (i.e. the status light continued to blink). I also tried holding the the help button for a while and that also didn't help.
    Any other suggestions?
  • scott_ben619
    scott_ben619 Apr 07, 2013
    When do you press that help button on the remote? at what point? when the projector is in stand by mode or whenits booting up?
  • Anonymous Mar 25, 2014
    image comes on for 20 seconds and then goes blank
Great site, thanks everyone. I came here because my NEC VT48 wouldn't power up after a lamp replacement, and holding down HELP on the remote for 10 seconds fixed the issue. Bravo everyone.
Posted on Aug 26, 2008
Try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Posted on Feb 20, 2008
I have an NEC VT470. The projector shut down after the lamp finished. When I replaced the lamp and pressed the start button, the projector does not come back on.
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual.
Good luck
Jan 14, 2011 | NEC (VT75LP) Projector Lamp for VT470,...
My NEC MT1060R will not turn on and the status indicator is flashing red four times, before and after I changed out the lamp.
Some of the NEC units have a standby status when the lamplife has exceeded its safe limit, the unit I had needed the off button pressing for up to 20 seconds to reset the lamplife and allow the unit to be switched back on. There should be info for this in your manual. (It could have been the on button, can't remember now)
Good luck
Nov 30, 2010 | NEC MT860, MT1060, 1060R and 1065...
Picked up a nec MT1030+ on a gov auction with no remote. Lamp hours have exceeded the 2100 and projector is shut down. With out remote how do I get it back on? I guess I should be specific here. I have...
First make sure that you have install the bulb correctly. There are number of issues that can cause this problem.
1.Check for dirty air filter and clean if need. Make sure the air filter cover is on all the way. Make sure the cover to the lamp is on all the way, and that the screws are tight.
2. First turn off and unplug the projector. Then remove and reinstall the lamp, with cover firmly fixed. Make sure are cover are properly fastened. You should get the projector to turn on by pushing the power button on the unit. Wait for an hour if you keep having this problem, then plug the unit back in.
3. Then reset the lamp timer. Sorry I don't how to reset the timer. I home manufactured an LED lamp for mine, so I don't have to worry about replacing lamps anymore.
You might want to ask someone here on the fixya forums how to do a hard reset of the timer and unit.
You might find projector central.com helpful, where the owers manual for the MT 1030 is available in PDF version.
http://www.projectorcentral.com/NEC-MultiSync_MT1030+.htm
May 13, 2010 | NEC MultiSync MT1030 Multimedia Projector
My nec vt46 does not want to turn on
You need to check the manual. It will tell you at the rear what the different lights mean.
Apr 13, 2009 | NEC VT460 Multimedia Projector
NEC MT1050 Lamp Error
Does the status light stay on red? If it does then the lamp timer has exspired and will not let the projector turn back on until it is reset, at which time you should replace the lamp. To reset the timer you need the remote control, with the unit plugged in in standby mode hold down the power off button for 30 to 45 seconds until the status light goes off.
Feb 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
How to reset Time clock on NEC MT830+ Projector
change the lamp even if the old lamp
use original nec remote contro
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
Sep 20, 2008 | NEC MultiSync MT830 Multimedia Projector
NEC VT676 lamp error
indicating ballast unit problem
Sep 11, 2008 | NEC VT676 Multimedia Projector
NEC MT850
As there were no indicator lights lit I focused on the AC. The projectors work as they should in another location and as such I am fairly certain the problem is associated with the AC power in the particular room. I haven't isolated the exact condition as yet.
Thanks
May 20, 2008 | NEC MT850, MT1050, MT1055, MT1056...
Dark Picture
If the Lamp condition is okay then check the FE lens just next to the lamp in the projector after removing the lamp out of prj. replace if that is burnt.otherwise replace Lamp.
Viren
Nov 13, 2006 | NEC VT460 Multimedia Projector
NEC VT460 Multimedia Projector Logo
3,049 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
