Rca stereo my stereo says it is overload how do i fix it
  • Anonymous Apr 21, 2009
    My RCA displays overlad on the screen yet it was my fault cuz i put both of the speakers wires in positive but it does have power displays time and everything and i would like to know if it will work again or not?
  • 49 Answers
Once you correct the wiring issue ensuring you match the positive side of a speaker with the corresponding Left or Right output on the back of the stereo. Once you power the unit on, it shouldn't say overload. If it does, try looking in the manual for a reset button (I assume you have unplugged and plugged in the unit) to reset the amplifier circuitry.
If the unit still reads overload then that would suggest damage was done to the amp when you shorted the output (high volume, power on while changing the wiring, etc.)
Good Luck
Jer
Posted on Jan 21, 2010
Sorry insufficient detail for an accurate response.....
Please post more detail...
Cheers YUBEUT
Posted on Feb 15, 2008
Jvc home stereo receiver overload
Could be a voltage, volume from preamp or the wiring on the speakers is crossed
May 04, 2014 | JVC COMPANY OF AMERICA HEADPHONES - HOME...
Rca receiver overload message
Power the unit off , Disconnect all the speakers ,power the unit back on and check to see if you get the same message, if so one or all of your speakers could be bad. This message appears when there is too much load on the output IC's,generally causes shutdown. Also try blowing the system out with canned air, And removing anything that prevents the unit from getting enough ventilation.
Feb 21, 2014 | RCA Stav-3870 Audio Video Stereo Receiver
Pioneer receiver overload
The "Overload" message usually involves the speakers or the speaker wires. Disconnect the speaker wires and make sure that they aren't frayed or damaged. (When you reconnect them, make sure that no loose wire touches the receiver case, speaker or another wire.) Replace any damaged wire. Make sure that none of your speakers have a lower impedance than the receiver can handle. (Most Pioneer systems have a 8 ohm limit.)
If the message persists, turn off the system. Disconnect one speaker at a time and try turning on the receiver and turning up the volume. If the error disappears when one speaker is removed, that speaker may be damaged and needs to be serviced. Do not reconnect the speaker to the receiver until it is fixed.
I hope this helps.
Jun 20, 2013 | RCA Televison & Video
What cable goes from the tv to the system so I get sound from both the system and the television
On the back of the TV, there should be a set of RCA audio output jacks. Colored red (R) and white (L). Buy a dual (red/white) RCA cable in the length you need. Plug it from the TV's RCA audio outputs to your stereo receiver TV input, or any unused input (but not phono/turntable in). Select that input from the choices on the front panel of stereo receiver.
Now, the RCA audio output from the TV might have a choice of variable or fixed level out. Adjustment is via the audio properties in the setup menu.
Variable means when you adjust the voulme on your TV, it affects the level going to you stereo receiver.
Fixed means that the audio output from the TV is a steady signal, and the adjusted volume on the TV does not affect the level to your stereo receiver.
I would choose FIXED. Hope this helps.
Apr 03, 2010 | Nakamichi AV-2 Receiver
Receiver Overload error message
Disconnect all speaker wires at the receiver, then turn it on and up. If it stays on, check your speaker wires one by one, then check your speakers one by one. If it still cuts out with nothing attatched, it needs serviced or replaced.
Aug 30, 2009 | RCA RT2660R Receiver
Amp a2801q
Audiobahn A2801Q
Product Description:
Class A/B MOSFET Circuitry
200 watts x 2 @ 4 ohms stereo
280 watts x 2 @ 2 ohms stereo
560 watts x 1 @ 4 ohms mono
Volt Meter With Blue Illumination
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
Variable 18dB Low-pass Crossover: 30Hz To 120Hz
Bass boost @ 45Hz: 0/18dB
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
1-year warranty
Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
Buzzing noise
I had the same problem with mine and the fix for it was to replace the Q401 transistor on the main board. I used a NTE382
replacement and has worked fine ever since.
Hope this helps
Aug 26, 2007 | RCA RS2640 CD Shelf System
Help
open it up then plug it in. when you press the power button see if one of the large white boxes (there are six in a row) lights up red.
Sep 29, 2006 | RCA RT2360 System
POWER ON PROBLEM
Well, I know that u will overload it if u use any 4 ohm speakers on it. And a LOT of center channel speakers are 4 ohms. Also, it has problem working with 5.1 (optical or coaxial). If that is the case, try to run it on stereo...
Oct 11, 2005 | RCA RS2604 CD Shelf System
240 people viewed this question
 Grubhead
Grubhead
