Question about JVC AV32F577 32" TV
Auto channels i bought a jvc tv, model av32f577, with no remote or guide and i need to scan for channels but can cause i have no remote or guide. how do i manually do it by the front of the tv.
    Problem Solver:
  • 5 Answers
Is there MENU KEY press it then enter and install or tunnig option choose it and tune which channel you want
Posted on Feb 10, 2008
XCAN'T FIND THE BUTTON TO RUN CHANNEL AUTO SCAN
First make sure that the Source is set to TV and a good antenna/coaxial cable is connected to the TV. Use the Input button on the TV (to the left of the power button) or the Input Select button on the remote. Use the up/down arrow keys to navigate through the source list and press Enter to select that choice. (On the TV, the Input button is the Enter button.) Next press the Setup/TV Menu on the remote (or Menu on the right arrow button or Enter. Then go down to Auto Ch Memory and press the right arrow or Enter. With the up/down arrows, navigate to Signal Type and set that to Air (for OTA channels) or Cable with the left/right arrows. Now navigate to Automatic Search and press the right arrow or Enter. Wait for the scan to be completed.
I hope this helps. The steps are shown in the manual for the LT-19D610 on page 18. The manual is available from JVC on the product page: http://support.jvc.com/consumer/product.jsp?modelId=MODL028825 . The direct link to the manual is http://resources.jvc.com/Resources/00/01/47/J55D0221B.pdf .
Dec 05, 2015 | JVC LT-19D610 19" 720p 1366 x 768 35000:1...
Jvc gennessa how to scan for channels
need to know if a cable box is used. If using the built in converter there are more than 1 positions that can be selected. On one setting some channels are omitted. A channel scan is usually on the remote that came with the tv. It is under the menu option to do a channel scan.
If some are skipped try to manually put the channels in to see if anything is there.
Mar 19, 2013 | Televison & Video
How to scan for TV channels
Channel searching is performed as part of the setup process. Your remote should have a way to direct the TV to display the setup steps
Jan 10, 2013 | JVC LP21036-023A Remote Control...
Power light turns green as soon as you plug in tv but tv does not turn on
Based on model number someone is going to have to open set and start checking for voltages or shorts--that simple.
Jun 12, 2012 | JVC AV32F577 32" TV
How to get chanels to be auto store on remote
Just do a channel auto search through the menu and channels should be memorized.
Nov 09, 2011 | JVC Televison & Video
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
There is no local channel,cable only international..i lost my manual,
Hello
Here is the procedure for auto tuning. Pleas go through it. Connect the antenna to the rear antena socket marked as &% ohms antena and continue.
If you have already run the Auto Tuner as part of the quick setup earlier in this guide, please
skip ahead to "Channel Summary" to continue setting up your television. In Auto Tuner Setup,
the TV automatically scans through all available channels, memorizing the active ones and
skipping over blank ones or channels with weak signals. This means you scan using the
CHANNEL +/- buttons), you will receive only clear active channels.
Press the MENU button
?† To AUTO TUNER SETUP
?® To operate
?® To choose CABLE or AIR
Press the OK button to start
Initial Setup
Auto Tuner Setup
Programming will take approximately 1 to 2 minutes. The auto tuner is finished when the
message PROGRAMMING OVER! appears onscreen.
Channel Summary
Channel summary allows you to customize the line-up of channels received by your TV. You
can add or delete channels from the line-up or prevent any unauthorized viewers from watching
any or all 181 channels.
?† To CHANNEL SUMMARY
?® To operate
The Channel summary screen will now be displayed with
the channels set to scan marked with an "?". You can delete
channels from the scan by removing the "?". If any channels
were missed during auto tuner setup and you wish to add
them, you may by placing an "?" next to the channel number.
?† ?® To the SCAN column
Press the OK button to include or delete from scan
Press the MENU button when finished
You can block access to a channel by activating the channel lock.
?® To operate
?† ?® To the Lock Column ( )
Press the ZERO button to lock or unlock that channel
AUTO TUNER SETUP
CABLE
If you wants any codes, contact me through Fixya. Ok
I'm quating these procedure from the manual I've with me, and it is for JVC AV32S565.
Nov 08, 2010 | JVC AV-32S575 32" TV
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Channels won't change on tv with remote or manually
hi,you need to auto search first your your t.v set if nothing happen possible defect is the tuner.
Aug 03, 2009 | JVC LT-32P679 32 in. LCD TV
JVC AV32F577 32" TV Logo
540 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
