Question about Canon i850 InkJet Photo Printer
Canon i850 lid over ink cartridges will not close
Never had this problem before, but the "lid" which closes over the ink cartridges and holds them in place, will not close. What's up?
  • dbaird Feb 12, 2008
    Thanks Jeppy2. I couldn't remove the print head as you suggested, but when I pushed harder on the gray handle, it did close. I reopend it, reinserted the ink cartridges, and - with enough force - again closed the gray handle. I still don't know why it doesn't easily close like it usted to, but IT IS printing fine. I'll look at the print head again the nest time I have to change cartridges.
It sounds like your print head may have dislodged and not be in the correct position, remove the ink cartridges and raise the gray locking handle completely, then lift out the print head and remove it completely ( its the tray inside the slider tray that has the nozzles for the ink tanks ) then reinstall, there should be a slight click when its in the correct postion, reinstall your ink tanks.
Posted on Feb 10, 2008
How to remove ink from printer
Ink Cartridge Maintenance
  1. Turn on your printer.
  2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
How to instal a new printer ink cartridge
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
Nov 22, 2010 | Dell 810 All-In-One InkJet Printer
How can i change the black cartridge for Canon i850?
Hi Sheril
I don't understand the question. You just open the lid and take out the cartridge and put the new on in then shut the lid.
May 18, 2010 | Canon i850 InkJet Photo Printer
I have a Lexmark X125 printer. I just bought new ink cartridges because I ran out of ink. I followed the directions on the printer to install the ink cartridges and the printer keeps flashing the words...
Remove the cartridges and close the lid. Allow the system to try to calibrate and complain. Open the lid. Check the cartridge bottoms to make sure you removed the plastic cover on the jet heads.
Replace the cartridges and make sure they clip. Close the lid to finish.
if this does not solve it. Remove the cartridges and then unplug the unit from the power. hold the power button down for 10 seconds then give 20 seconds more. this will clear all power. Place the new cartridges in and close the lid. power the unit on and test for success
Feb 14, 2010 | Computers & Internet
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
Where is ink cartridge keeps saying ink low never changed ink before
With the printer on, lift the lid of the printer. The ink carrier will center on the track. You can remove the cartridge that need replacing, insert the cartridge and close the lid. You should be good to go.
Download and review the instructions from
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Please rate this solution. Thanks.
Oct 15, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp145 E5 problem
Cannon has made their ink cartridges in a way that you have to buy new ones every couple of refills.This is a way to bypass that..worked on my MP145.
Reset Ink level Canon Printer Cartridges PG-40, CL-41, PG-50, CL-51, CL-52
To reset the ink Level (method 1)
  1. Paste with a thin strip tape the upper horizontal row contacts
  2. Insert the cartridge into the printer and close the lid.
  3. The printer will now on the move, but wait until there on the screen Your computer is the message that there is a wrong way to a Ink cartridge is loaded. Click OK in the message
  4. Open the lid of the printer and remove the cartridge from there.
  5. Download Now the strip of adhesive tape and paste it contact now on the Second row (from top) horizontal contactjes. (Picture 2)
  6. Insert the cartridge into the printer back again and closed the lid. Weather will The printer is on the move again, and again we place an alert on Your monitor. This time, the message that the cartridge can not Be recognized. Click on OK again
  7. Open the printer and remove now for the last time the cartridge from the
  8. Remove the tape and insert the cartridge in the printer and connect it Lid.
  9. The printer is the cartridge back as a new and indicates that the cartridge full again
Resetting the ink Level (method 2)
Works only in some cases
  1. Paste with a thin strip tape the bottom row of horizontal contact The cartridge off
  3. The printer will now on the move, but wait until there on the screen Your computer is reported that on one wrong way Ink cartridge is loaded. Click OK in the message
  5. Download Now the strip of adhesive tape and paste it contactjes now on the Contact uppermost horizontal row.
  7. Open the printer and remove now for the last time the cartridge from the Printer.
if that doesnt help... u will most likely be required to call canon...
thank you for using Fixya....
A very Helpful rating is appreciated...
have a nice day
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Can't change ink on dell 810. what do I do first? I don't know how to change ink in dell 810,I couldn't see how to take old one out as well and how to put new one please
Lift the priner unit lid on the printer llift he print cartridge lid,
Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed. Let me know if you have any questions.
Apr 14, 2009 | Dell 810 All-In-One InkJet Printer
Green light is flashing orange 4 times
Resetting the Printer
  1. Turn the printer off.
  2. Disconnect the data cable from the printer.
  3. Unplug the printer's power cord for approximately 10 minutes.
  4. Plug it back in.
  5. Reconnect the data cable.
  6. Turn the printer back on.
Dec 11, 2008 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
113 people viewed this question
old marine
old marine
