Question about Panasonic SC-HT680 System
Tray fault can i get a copy of a servicemanual to realine the mechanical section of my sa.ht680
    Problem Solver:
  • 19 Answers
My Panasonic sa-ht680 will play back round sound but no voice and when I try to change the surround it says error
Some sound systems have the option to switch off the Centre Channel. That might have happened here. But it could be a fault.
Jan 09, 2016 | Panasonic Audio Players & Recorders
Panasonic SA-PT460 disc tray don't opening
The tray mechanism tracks may be binding or the mechanism may lack sufficient power to move the tray.
Dec 30, 2013 | Audio Players & Recorders
The remote control for my Panasonic SA-HT680 was totally destroyed by 6 year old son (Boys will be boys). I want to replace it with a genuine replacement. Can anybody help me? I have also had the problem...
You can call Panasonic at 1-800-405-0652.
Be ready to give them model and serial numbers to find out availability of replacement remote.
Good luck ( with the remote and your son) !
Nov 29, 2010 | Panasonic SC-HT680 System
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
SA-HT680 F61 Error
Typically the F61 error is a protection error indicating that there is a problem with the output amplifier section. The failiing part is usually IC501 (part number RSN311W64D) which costs about $95. Have this unit checked as there are other possibilities.
Dan
May 05, 2008 | Panasonic Home Theater System System
Sa-ht680 service manual
The F61 indicates protect mode. There is a problem with the output stage of the amplifier section and the unit shuts down to prevent further damage. This unit will require service of the amp section. You can try to contact Panasonic for the service manual.
The output amp pac is an RSN311W64D at a cost of $95 plus shipping.
Dan
Apr 09, 2008 | Panasonic SC-HT930 System
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Bit rate showing at top of screen
is it possible to play my cable tv through my system
Dec 03, 2007 | Panasonic SC-HT680 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
Panasonic SC-HT680 System Logo
379 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
