Question about LG VX6100 Cellular Phone
LG VX 6100
My phone has a very weak signal, and I keep getting Analog signals, (and the phone won't connect on Analog). My software versions are: S/W version T6NVZ03
PRL version 50959
ERI version ERI 4
Browser version 6.2.3.1
Get it Now version 2.1.3.8
VR version S1680E4290A021
Does anyoneknow if there are there any later versions avalable, and what do I need to do to download, and install them?
    Problem Solver:
  • 7 Answers
Try opening the back cover of the phone. Look for the spring connectors of the antenna and its contact pads. Clean the contact pads and antenna connectors.
Posted on Nov 05, 2009
    Problem Solver:
  • 10 Answers
The antenna stub unscrews. Try tightening or replacing the stub.
Posted on Mar 08, 2009
I have a Samsung un55f7100af smart tv that all of a sudden has started self switching from hdmi to analog input. is this due to intermittent cable signal?
Some TVs will attempt to revert to analog if the digital signal gets weak, gets too much noise or is simply lost. I assume it is fairly quickly returning to digital? If this continues contact your cable provider. They will likely check you signal strength and make sure you have good quality connections.
Oct 05, 2014 | Televison & Video
LG vx8100 USB driver compatible w/ Windows XP
You neglected to infrome whether 32 or 64 bit
if 32 bit The drivers for 32 bit are standard USB handset drivers normally provided by the phone manufacturer (LG) They use the same drivers for many of their phones.. LG VX 6100, VX 7000, VX8000 and VX 8100. Possibly even more
If 64 bit you are out of luck at this time the solution
use a 32 bit version of XP without SP2 or with it maybe
you get lucky and it work
Dec 06, 2007 | LG VX8100 Cellular Phone
We want to hook our small Magnavox tv to a rabbit ear antennae to get only local stations. How to do this?
Unless this a new TV with ATSC (digital) tuning built in, you will need a digital adapter for off-the-air reception. Older TV sets have analog tuners, and analog broadcasting ended in June 2009. Wal-Mart and Radio Shack carry the adapters, as do other retailers. Your antenna connects to the adapter, and the adapter sends the converted signal to the TV on channel 3 or 4.
With digital broadcasting, a strong signal is necessary. Unlike the analog days, when a weak signal just meant a fuzzy picture, a weak digital signal will cause pixellation (blockiness) or freezing of the picture, or may not even be detected by the tuner. Depending on how far you are from the station's transmitter, you may find that rabbit-ears may not work too well. You may need an amplified antenna or even one outside to get best performance.
Aug 07, 2011 | Televison & Video
Lg phone will not pick up signal from verizon
Try hitting menu 0 or ##77647268300 and send one of these should get you into a programming menu(depends on the software version) service code is '000000' and you are going to check option under Network and band preference, should be set to 'Any' not 'cell only'
May 27, 2010 | LG VX8300 Cellular Phone
My itv channels keep breaking up or freezing since the switchover
I'm guessing the signal from the antenna is too weak. With digital, it will not get fuzzy as with analog, but rather will pixelate, go blank, or freeze. You need to figure out how to get more signal to the TV by moving or re-aiming the antenna, improving the connections (clean or repair), or amplifying the signal.
Dec 01, 2009 | RCA DRD485RG DirecTV DTV Receiver
I have a new LG vx8700 and I have a very weak signal.
On Verizon, sometimes you need to update the carrier settings. This is done over the air. Dial * 2 2 8 and press Send on your phone. It will go through an automatic process to refresh and reactivate so just be patient and listen....
Good luck!!
Nov 28, 2009 | LG VX-8700 Cellular Phone
Our lg42lt75 tv keeps freezing on dtv the only way we can it going again is to turn the power off .is there any way we can stop this?
Your current software version of the TV may be out of date, contact your LG dealer as this might have to be updated, older software can give this effect. If your incoming signal from an aerial source is weak then this can also cause problems the strength of signal can also be checked at the same time.
Nov 01, 2009 | Televison & Video
Won't keep digital signal
If you're connected to a digital cable box, I would try using the external component connections and bypass the TV's tuner. If all you have is straight cable coming into the house, it could be the cable signal itself or a defective tuner in the TV assuming all the menu settings are correct in the TV.
Jul 25, 2008 | Toshiba MW20H63 TV
Can only get dsl if i use landline
Hi, Rob just studied ur problem.Iam a tech which handles this kind of issue. I talk to verizon,at&t,bellsouth,qwest daily for such issues. Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty. And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible i:e NTF. For further clarifications plz get back to me.
Jun 07, 2007 | Westell Wirespeed LiteLine 6100...
LG VX6100 Cellular Phone Logo
124 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
