Question about Palm Treo 750 Smartphone
Palm Treo 750 camera takes pictures but video not working
I can use the camera to take pictures but the video shows a black screen always.
  • courtney4 Jan 11, 2009
    I have a black screen for camera and video.
How can i change the front panel of the palm treo
750
Posted on Apr 23, 2008
Palm treo 750 only shows the Palm screen on startup and nothing more
check soft ware at first , then hard ware solution by cleaning the board , be sure that keyboard is clean enough.....
Apr 20, 2011 | Palm Treo 750 Smartphone
Palm Treo 750 "no service"
my favourite (treo 750) i own 1 but not sure i have had that problem yet depending on if you install a program it could be causing that problem maybe a call blocker! u could check to see if ur network is on automatic
start-setting-personal-phone-network-netselection automatic
try backing up your phone data then master reset back to factory setting
N.B you would loose everything that cannot be backed up but this solved my bluetooth problem 1 time holding down the reset button then press power. when prompted to reset say yes
Feb 01, 2010 | Palm Treo 750 Smartphone
Touch screen broke
I had the same problem bought a replacement screen on ebay, search on you tube for instructions on pulling 750 apart and replacing screen only took 5 minutes and it works. If I can do it anyone can.
good luck
Jan 29, 2009 | Palm Treo 750 Smartphone
Screen replacement for treo 750
After removing the battery, you will find four star-head screws. Find the fifth screw by prying up the edge of the rubber antenna cover (opposite side of back from the stylus.)
Search youtube.com for video of instructions. Fairly High level of expertise necessary. I have replaced two screens. One worked, the other became tech-trash.
Jan 15, 2009 | Palm Treo 750 Smartphone
Camera
You can program the screen to lock while you are on a call.  Most likely you pressed something while on the call and it switched you to the photo gallery.  If you hold the option key and press end it will lock the screen while on a call.
You can program short cut keys.  Go to your settings are and you can find all kinds of neat things.
Good luck.
Jun 23, 2008 | Palm Treo 750 Smartphone
CAMERA
Check and see where you are saving your images.  I save mine to my memory chip.  If it gets too full it won't take any more pics.
You might be having a different issue with the black screen.  Have you gone to the programs section and checked your settings?
Jun 14, 2008 | Palm Treo 750 Smartphone
Palm treo 750
try a reset, if that doesnt work, then we can try a hardreset witch also removes all your files from the phone.
If a hardreset doesnt work then the phone is in need of repairs.
Mar 24, 2008 | Palm Treo 750 Smartphone
Palm treo 750 not ringing
Taking the battery out to switch your phone ON/Off can cause serious problems.
To receive calls, your phone must be on.
This is different from having only the screen turned on (see Turning your phone on). When your phone is off, your calls go to voicemail. To see a picture of the person calling you!
Learn how to assign a caller ID picture in Assigning a caller ID ringtone. If music is playing when a call arrives, the smartphone rings softly. You can answer the phone as you normally would. The audio pauses during your call. To answer a call, do one of the following:
• Press Phone/Send .
• Press Answer (left action key).
• If the headset is attached, press the headset button.
To ignore a call and send it to voicemail, press Menu (right action key) and
select Ignore or press the Power/End key.
Waking up the screen and turning it off.
Wake up the screen and leave the phone turned off when you want to use only the organizer features of your smartphone, for example, when you’re on a plane and want to look at your calendar. You can also turn off your smartphone’s screen without turning off your smartphone’s wireless features. You can turn your screen on and off by pressing Power/End.
Mar 08, 2008 | Palm Treo 750 Smartphone
Palm Treo 750 Smartphone Logo
98 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
