Question about Dryers
How to hookup the dryer heater. i have conected all wires except the one to the coils. it is a kenmore mdoel # 11066662500
Iiremambered ehere the wires wint oroblem solved
THANKS
Posted on Feb 10, 2008
Kenmore #11066742500 dryer
Could be several things. If it is a new hookup the neutral and one of the hot wires has been reversed. If it just started doing this the most probable is a shorted heating element. It will still test good on continuity test but part of it is touching the frame. The third thing is a bad thermostat, it would be cycling at too low a temperature. The temperature coming out of the exhaust should be between 150 and 175 at high heat.
Jan 21, 2012 | Dryers
I want to put a new 4-wire/prong dryer cord, and I don't know how to conect
Hi sacra4487...
Go to this webpage and see a picture of how to hook up your dryer cord
Free Answer...Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jun 12, 2011 | Crosley CDE6000 Electric Dryer
No heat and believe it to be the thermal fuse on kenmore dryer 63
Unplug it, remove the back, f73a9b7.jpg1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. heater assembly.
3. 250f limit (if bad no heat, timer won't advance)
4. heater element
5. Fuse(350F), if blown(open) the dryer will NOT run.
(if you do not have a meter remove and inspect this heater coil for breaks).
6. control thermostat
7. heater (warms thermostat to shut it down faster for delicates)
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 13, 2010 | Kenmore 63942 Dryer
How to find the heating element on the Kenmore 80 series... Model 67832794... trying to replace myself but can't figure where the heating element is located
remove the back of dryer,unplug,look to the right and you will see the heater box,the lower half is the heating coil,remove the 2 wires and 2 screws and pull the heater off,also you need to check the heater box fuse located on the upper left side fg heater box-mike
Feb 19, 2010 | Kenmore 63942 Dryer
Our drying is not heating up and its not drying the clothes whats wrong with it and how do i fix it?
our drying is not heating up and its not drying the clothes whats wrong with it and how do i fix it?
Dec 30, 2009 | Kenmore 62602 Electric Dryer
Bad heater coil or prong
Assuming you have all wires disconnected from heater and only 2 terminals remain near the bottom of the heater can. A reading of "open" has to be the heater. You should be able to see a break in the coil when you remove heater.
Aug 22, 2009 | Kenmore 63942 Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Kemore Elite Dryer - no hot air
kenmore gas dryer heats at first, then cools off rest of cycle.
Jul 26, 2008 | Kenmore 74602 Gas Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
49 people viewed this question
Top Dryers Experts
Marvin
Marvin
