Maytag A512 Leaks out airgap when draining/spinning out
My A512 Washing machine leaks water back up the injector tube and the water comes out of the airgap vent when it is spinning out/draining.
I have checked all drain lines and the pump for restrictions/blockages
The injector tube "picks up" the water as the spin cycle starts and about 4 oz of water hit the floor.
Should there be some kind of "deflector on my inlet tube??
  • Anonymous Jun 20, 2008
    when the machine fills up water leaks out the back, and also when the spin cycle is on, whats the problem?
  • 24 Answers
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
Posted on Oct 08, 2008
Maytag heavy duty washing machine quiet series 100 leaks water from the top panel
Older maytags were equipped with an "air-gap" that can leak if the rubber sleeve part of it gets too stiff and cannot flex. It is along the left hand side of the machine fastened by a 5/16" screw between the machine cabinet and the upper panel... Maytag Injector Tube 12001677
If you remove the front panel and set the machine to fill, you should see water dripping off of the plastic frame the injector is sitting in.
If it is a newer maytag, check the fill spout for cracks or sediment build-up Maytag Water Supply Tube WP3360977
Jun 06, 2016 | Maytag Washing Machines
Maytag washing machine model a 210 (1982) leaks above filler. how do i get into cabinet to check natureof/cause of leak?
see this cause and fix it:
During fill only
air/gap deformed or crack , replace see the diagram
the rubber tube run between water inlet valve and air gap can cause leak +inlet spout can be crack cause leak replace.
During drain and spin only
inspect main drain hose and fix it. steel or plastic outer rub can be rust,split if this happen you must replace the entire outer tub.
All the time
check the hot and cold hoses water tighting or replace
main tube seal leaking
pump defective leaking.replace
outer tube, split , rust, causing leak, replace
see the diagram
God bless you
7_19_2012_7_39_57_am.jpg7_19_2012_7_40_20_am.gif7_19_2012_7_40_43_am.gif7_19_2012_7_41_02_am.gif
Jul 18, 2012 | Maytag Washing Machines
Washing machine leaks during spin and drain cycle
If the leak is still present after you replace the hoses , you may need to get a new water pump ( cheap part ) it is probably leaking , it removes the dirty water from the washer during spin and rinse cycle . hope this helps
Jun 28, 2012 | Washing Machines
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Water leaks from under during spin cycle
There are multiple reasons why your washer would leak during the spin cycle. The wash tub seal could leaking, The tub bearing could be leaking, The carbon seal on the top of the tub boot could be worn. The water injector tube where it connects to the top of the tub could be torn from age. Even the tub to pump hose could have a hole in it. These are the most likely causes. There is one more item being the stem seal could be shot but this would cause water to leak all of the time.
Jan 06, 2010 | Maytag Washing Machines
Water leaks from the bottem of Maytag Neptune front loader
Your sewer drain may be backing up.
Check the drain during a final spin.
Feb 26, 2009 | Maytag MAH8700AWM Neptune Front Load...
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Maytag Performa PAV2300 washer leaks
Hi hindsr
I dont know for sure what it is but i would guess that the tub is going off balance during the spin just befor the rinse and the tub is not centered. so what happens is watter hits the top of the tub and runs down the back (inside) and thats where the water is comming from.
brent
Sep 22, 2008 | Maytag Performa PAV2200
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
760 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
