Question about Maytag Neptune MAH5500B Front Load Washer
Washer door latch stuck, can't open
THIS WASHER THINKS THE DOOR IS OPEN, WHEN IN FACT IT IS LOCKED CLOSED. i HAVE POWERED OFF SEVERAL TIME, EVEN REMOVED POWER, HOPING IT WOULD UNLOCK DOOR MECH.IT WON'T. I CANT OPEN THE DOOR AT ALL. DOES ANYONE HAVE A SOLUTION, LIKE ENTERING A SERVICE CODE, OR HITTING A SECRET EJECT BUTTON????
  • LCS29 Feb 10, 2008
    Thanks for your reply. I found the answer on this website. Found the release string, located inside soap dispenser area ( have to remove lid,4 screws) looks ike a weedeater string. Pulled while opening door, IT WORKED!!! YA!!!!.......I am now washing my clothes. I think I may either have a flaky relay, or a flaky door latch assy. Now I know where to ER release the latch, I'm going to run to see if it fails again.Thank you so much!!!!!
  • jiplejo Dec 25, 2008
    I have the same problem with my frigidaire front load. Where is the release cord located? I have the service panel off and can't feel a cord only the connections to the latches
    Genius:
  • 3,587 Answers
Ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
Posted on Feb 10, 2008
  • Patrick Michaels
    Patrick Michaels Feb 10, 2008
    You are most welcome.
  • Patrick Michaels
    Thanks for the opportunity to help you out.
Driver's side door latch won't budge once closed. Locked or unlocked the outer handle acts like the door is locked. Any suggestions?
The outer handle has a spring to return it built into the handle I think, so the fact that it returns does not mean it isn't disconnected inside the door. Time for a shop I think (are the replacement switches really $500? Might check with a parts store instead of dealer to see if they can supply that part.)
Jun 30, 2014 | 2001 Isuzu Rodeo
Having trouble with keyless remote control on 1993 lexus es300. Replace battery on remote- still not openning doors. Help Please!
Try reporgraming it
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Jan 02, 2013 | Cars & Trucks
Door is locked wile the door is open on whirl pool duet how do i get it unlocked
Try turning the power off at the wall, leave it off for 2-3 minutes. If the lock does not release then it is likely a faulty lock spring. By default these locks should release when there is no power applied, a solenoid holds the lock closed while power is applied and a spring releases it when the power is removed. Some machines will "store" power for several minutes even when unplugged so the leaving it unplugged for 2-3 minutes may be needed. If this does not fix the problem you will need to remove the lock and have it serviced or replaced.BTW did you look to make sure there isn't something jammed in the door lock, it is amazing what can get stuck in that little hole. Be careful poking around in there though as there is power supplied to the lock, as always safest to switch off the power before playing.
Jan 04, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Having trouble with my whirlpool cabrio . . . showing "DU" . . .
The F30 error code (dU) will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
TEST #8 Door Lid Lock
Perform the following checks if washer fails to lock (or unlock).
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa!
Jan 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer displaying du code with 3 quick beeps
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
If it is a cabrio:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I need to know how to program a remote alarm control for a toyota 4runner 2000
f
1. Start with the following conditions: you are in the vehicle
a. Key is out of the ignition
b. Drive door is open ( all other doors are closed)
c. Driver door is unlocked (other door locks don't matter)
2. Insert the key into the ignition (don't turn it) and pull it out.
3. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times. Use an even pace and try
to go relatively fast.
b. Close, then open the drivers door.
4. Perform these steps within 40 seconds:
a. Cycle the power locks 5 times (same as before).
b. Turn the ignition to ON then back to OFF.
c. Turn the ignition to ON then back to OFF.
d. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should cycle (automatically)
indicating successful entry into programming mode. Return to step 1
if the locks do not cycle at this point.
6. Perform these steps within 40 seconds:
a. Press the LOCK and UNLOCK buttons on the transmitter
simultaneously for 1 second.
b. Immediately after letting go of the lock and unlock buttons,
press the lock button by itself and hold for 2 seconds.
Within 3 seconds, the door locks should cycle ( LOCK then
UNLOCK) once-- indicating successful programming. If
the door locks don't cycle, or cycle twice. Repeat steps
6a and 6b--this remote has not been accepted.
c. Repeat steps 6a and 6b for EACH transmitter that will
operate the vehicle. Including any old transmitters.
7. Close the driver door.
Also can check this procedure: http://www.toyota-4runner.org/60925-post2.html
Hope this help.
Mar 22, 2010 | 1997 Toyota 4Runner
Need to program a new remote
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes:
c. Driver door
6a and 6b--this
Hope this helps you, it did me greatly-- Good luck,
Mar 04, 2010 | 2000 Toyota 4Runner
Lost remote and like to program new remote. HELP. 2000 prado vx.
1. Start with the following conditions: you are in the vehicle a. Key is out of the ignition
3. Perform these steps within 40 seconds: a. Cycle the power locks 5 times. Use an even pace and try
4. Perform these steps within 40 seconds: a. Cycle the power locks 5 times (same as before).
6. Perform these steps within 40 seconds: a. Press the LOCK and UNLOCK buttons on the transmitter
Good luck and hope this helps.
Nov 04, 2009 | 2000 Toyota Land Cruiser
1990 accord ex power door lock
I don't think is the modual control due to the fact if it would be your control modul then it would not open anyway either using your key to unlock. My feeling on this is that either your connection on your alarm is not sending the right voltage to the unit and therefore you are not getting the signal. I would check your connection in your alarm unit and then if that is not the problem, I will replace the modul. Hope it helps!
Sep 08, 2008 | 1991 Honda Accord
Keyless entry remote
Try this, it works on several 2002 models:
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the drivers door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the drivers door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks.
Jun 20, 2008 | 2002 Mazda Protege
Maytag Neptune MAH5500B Front Load Washer Logo
537 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
