Question about Sanyo EM-Z2001S Microwave Oven
No workee
My wife reported that the microwave just stopped working altogether with no sounds, display, etc... After testing in another outlet, still no working. I opened it up (easy enough) and replaced the fuse with another 250v/20a fuse. Still nothing. Upon further inspection I found a "burned out" spot on top of the piece with the radiation warning. It looks like a disk metal piece that is underneath a black piece....I guess it would look like a stack of black mento's with two electrical lines running into it (or one in/one out). After jiggling it, the power came back it obviously stopped the operations.
What is this it just this part that failed, or is there something else that would have caused this part to fail? If you need a better description, please let me know. Thank you....I am hoping to be my wife's hero.
  • 96 Answers
Hi, Your dead on the money, this or called thermal shoutdown switches, when the unit get's to hot this will protect it again's over heating, on this peace there will be marking , this marking will be the temp. of shoutdown and other number for part #.
Go on googles and try the part # you will see it come up and just replace it. If you have another scrape micro you can take out the other and used it there mostlicly the same thing
Hope this Help
What About Bob
Posted on Feb 11, 2008
Kenmore Elite countertop microwave model 721.79153010 has no power, completely stopped working.
has an internal fuse. but you need to find out why it has blown, has it been making any funny sounds while cooking. ??
Mar 09, 2014 | Kenmore Elite 1.5 Cu. Ft. Countertop...
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Cookworks microwave grill and oven has stopped working. The display looks as it should when programming to cook, but the microwave steamer comes out cold. There is no obvious fault. The turntable works,...
I have just suffered the same prob..
breaking the rules...looked inside. Noburn out on the PCB,. The only fuse inside is still intact. All woks axcept the microwave...Help!
Oct 06, 2010 | Microwave Ovens
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
We have a Goldstar mv1310w microwave that the lights have quit working on. This is the light over the range that you can turn on while cooking on the stove. We put new bulbs in and I even show voltage on...
mcdevito75 here, It could be the light sockets are dirty from cooking fumes, oil etc, remove power from the sockets and clean them with alcholol and cotton swabs or paper towels etc.
Jun 28, 2010 | Goldstar MV-1310W/B Microwave Oven
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
Sanyo EM-Z2001S Microwave Oven Logo
185 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
