Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire p/n 154457601
My timer seems to be sticking in at least 2 points. Do ya think I need a new timer, or is some other switch or valve causing this?
    President:
  • Frigidaire Master
  • 2,651 Answers
Could be a heater, or a bad thermosta stalling your timer, check heater for continuity
Posted on Feb 23, 2008
Frigidaire Affinity gas dryer problem
I would bet you need new door lock switch
Jul 13, 2017 | Frigidaire Dryers
My GSX4756 dishwasher seemed to stop mid cycle and the start light is flashing. I have pressed the start button until the light goes out but as soon as I close the door it starts again on the rinse cycle...
I think.
However, rarely have I encountered an inlet valve that emitted a burning smell. So I'd expect there to be some other problem in there.
But, if the inlet valve didn't pass the test, then it needs to be replaced. Plus, if it was stuck on the rinse cycle and the valve was out, then that is where the cycle would hang up.
Burning smells usually come from a motor, a belt, shorted wiring or a heating element. So if everything else checks out, then go for replacing the valve. The instructions are included in our dishwasher repair section.
Jun 27, 2008 | Bauknecht Dishwashers
The water runs in the tub but never stops. Even if you put it on spin to run the water out. The water never stops till it runs over the top of the tub. Is that something in the main control timer that is...
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Maytag HAV2557 Top Load Washer
I have a GE Timer Cat. No. 58280 and the paper or stick on dial with the settings has disappeared. Is there a dial that I could print and re-stick on to my timer? Thank you!
I think I found a solution: this appears to be a single-outlet version of GE 06655 Light-Sensitive 8-Hour Dual-Outlet Timer. I have tried matching the dial settings from the online image and it seems to work. There are seven settings on the timer switch. Set the pointer of the rotary switch dial so the ridge clicks into place with one end pointing precisely at the triangular switch position indicator. This is the Off position. Turn the dial one click clockwise, this is the Always On position. Then comes the 2-Hour setting, meaning it comes on at dusk and turns off after two hours. Then come the 4-hour, 6-hour and 8-hour settings. Finally, the Dusk-till-Dawn setting.
Nov 30, 2010 | General Electric Hardware & Accessories
Timer is working but stops but stops at the on and off points like it don't have enough power to engage switch, timer is less then year old.
The pins push the lever.
New T-104 comes with a bit of white grease on the lever.
The lever is connected to the manual override.
Click the manual override back and forth. It should click firm and crisp.
If the manual override is sluggish or it sticks, then timer might be bad ... buy a new T-104 and snap the new insides into the box without changing out the box ... and if you bought it at the local store, then return the new timer with the old insides.
If the manual override works crisp and clean, then the clock motor may be bad.
Clock motors and Intermatic timers run for years, but the clock gears are plastic.
You can buy a T-100 series 240Volt clock motor at WW Grainger for $16
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK2?Pid=search
I think you need a small star screwdriver to change clock motor
Finally, the main dial gears are steel. If timer is exposed to moisture and dirt, the gears can get rusty and that might cause dial to stall. Snap out the insides and clean out the dirt, spray a bit of WD-40. Turn off electricity because WD-40 is extremely flammable.
Up-vote if this information helped. Thanks for the feed back.
Oct 14, 2010 | Intermatic T104R 208-277Volt 40-amp Timer...
My cw series is a plumbed-in unit. Water flows continuously from the spray head. I think that either (1) the water level sensor is bad (2) the shut off valve is stuck open. Ideas? Can the water level...
The CW series brewers do not have level probes they run strictly on a timer and a solenoid to control the water flow. So, that said, the problem could be the solenoid. If the brewer constantly drips/runs even when the front "ON/OFF" switch is off then it is the solenoid. If the brewing stops with switch off then it is the timer. The timer is located in the panel behind the filter basket on the front of the machine (6 screws) If the brewer has a manual timer set it to about 2 minutes, a good starting point for a pot of water (1/2 gallon). If it stops brewing then you need to fine tune the timer to give you right amount of water for your brewing method. If it doesn't stop... then you will need a new timer. If your brewer does NOT have a "dial/manual" timer follow the instructions on the backside of the panel to "reset" the brew level. If it does not reset you will need a new control board. Hope this helps.
Oct 05, 2010 | Bunn CWT 15-APS Coffee Maker
Gas will not turn on to heat dryer...igniter is ok...tested that...got new solinoids for gas valve seems to be back to timer but do not know for sure took that apart and points seem to be ok no hot spots...
Sometimes the heat sensor/ igniter gets carboned up and needs to be lightly sanded or cleaned for it to sense heat. That could prevent the main gas valve from opening and staying open. Also, does your unit have a heat limit switch or thermal switch that could be faulty? Check the wiring diagram.
Jun 12, 2010 | Whirlpool LEN2000PW Dryer
Frigidaire FTF530F won't advance
Possibly the timer. next time it wont stop filling turn off the washer. if it still fills you have a water valve issue. Hope for the valve. Timers are big bucks.
Jan 24, 2009 | Frigidaire FTF530FS Front Load Washer
Frigidaire dishwasher dirty & sticks in cycle
First, check the holes on the upper spray arm. They should be clear of food and debris.
Next, There's a check valve (ball) built into the motor unit. Either it's stuck, or the motor isn't pausing at the appropriate time to switch from bottom spray to top spray. You can test the check valve by opening the door momentarily while it's running. The spray noise inside should sound distinctly different. Pausing longer will switch back to the lower spray arm.
If the check valve works, you'll need a new timer.
Mar 10, 2008 | Dishwashers
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
455 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
