Question about GE Profile Spectra JGB920SECSS Gas Kitchen Range
GE JGB920sec2ss: Igniters dont light up burners
I have the GE JGB920sec2ss. Only one of the burners now light up the burner. ANother one occassionally does it. And the other 2(diagnal) burners dont click/crackle or ignite the burners. Any suggestions? Thanks.
  • vw9901 Feb 10, 2008
    Let me clarify. When i switch on the knob, half way thru (as it should) the igniter(white posts next to the burner)sparks correctly as designed for only one burner. For the other 3 burners, it sparks at the wrong burner/s, and not at the burner where gas is flowing (no problem with gas flow at all 4). For some strange reason ,the sparking happens on two diagnol burners, and mostly the ones which were not switched on (and hence have no gas). What could be a solution and what parts and could it be a DIY soluiton? thanks.
    Range is only about 6yrs old. Have not been serviced or opened up so far. Well maintained, generally.
    Genius:
  • 3,587 Answers
Two options on these..
1..the air to gas mix may be altered, from being clogged.
2. The gas lines are crudded up with grease/oil, etc.
How old is your range?
Posted on Feb 10, 2008
  • Patrick Michaels
    Patrick Michaels Feb 10, 2008
    the igniters CAN get corroded, after six years, I'd expect them to. I've seen commercial ranges with exact same problem, and replacing igniters, for some strange reason, did the trick. Guess there's more to those than meets the eye. As long as gas is flowing well, then it's most likely the igniters themselves.
  • Patrick Michaels
    Hope this works out for you well.
    Genius:
  • 3,422 Answers
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad.
When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner.
One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad.
Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure.
If you have any other problems please ask me..
Goodluck,
Please don't forget to rate me as fixya..
  • Priya darshan Feb 10, 2008
    See that is what i told you to replace the ignitor..
Why won't the top burners light or perform at 100% on my frigidaire glgf377ase?
sounds like the gas supply line to those burners are clogged. a needle or toothpick should unclog them with no problem
Jul 14, 2012 | Frigidaire Kitchen Ranges
Trouble with front burners: Right burner sparks but does not light Left burner does not apper to spark, but lights If you turn on both bruners they some times light???
The igniters for the burners are all on one circuit so when you turn the burner to light the switch inside the burner valve will cause all burner igniters to come on. As far as the left burner not sparking it could be due to a bad igniter switch in the valve and when you turn on the right burner you are causing all(including the left one) to spark. You will need to make sure that the burner eyes are clear and not plugged. You can use a sewing needle to clear out the eyes. The small eyes at the igniter electrodes are very important because if they are clogged the burner will not light.
Jan 15, 2010 | GE 30 in. JGP328 Gas Cooktop
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
GE Gas Kitchen sealed burner
I unplugged the wires from each end and re-attached the wires. Stove working great, no more clicking.
Dec 29, 2008 | GE Kitchen Ranges
Igniter on Burners Firing
Located on top each burner control valve is a switch that controls the igniters. One or more of these switches has failed
Dec 25, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
I have fix that problem before, the oven heat is soficating the top burners, you will have to adjust top burners with the oven on, so that they will light by them selfs.Or put a shield under the cook top section on the back, so that the heat will not come to the burners where they get the oxigen.
Dec 07, 2008 | GE JGBP28 Gas Kitchen Range
Burners won't light
Sounds like an igniter problem. Sometimes the tips of the igniters burn and don't give out the spark to light the burners. Check for a spark from the igniter on the front burners. Also sometimes the igniters drop down a little - may just need re-positioning. Compare the front igniters with the back to see how they should spark. You may need to replace the front igniters. Hope this helps.
Regards
Bryan
Feb 19, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniters won't turn on & unwanted flammes
You say you have no sparks coming from your gas range, but your rear burner is lighting. That doesn't quite make sense. If some of your burners are lighting, then the problem can't be with the spark module. The spark module sends a spark to ALL the igniters at the same time. That is, EACH burner switch, when turned to ignite, will cause a spark to go to ALL the burner igniters at the same time. Just watch the next time you turn one of your burner switches on, and you'll see a spark at all the burners simultaneously. This is normal. I suspect that you have a bad igniter switch or wiring harness. For example, if you have a front burner that won't light, but WILL light when you turn on another burner, the spark is being provided by a working burner switch. This is also normal. Now, am I assuming that your back burner will not light properly, but will light if you use the front burner? If so, the burner switch for the rear burner is probably bad, or the wiring harness has a break somewhere. Now...if you have no sparks, as you say, but randomly a burner will light, then I would suspect a bad spark module. I hope I'm not confusing you here. In a nutshell: One burner doesn't work, but all others do - bad burner switch, or wiring harness. No burners light, or light randomly - spark module. I hope this helps you.
Jul 28, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove burner igniter does not work.
Your problem is not the igniter itself, but the burner switch that controls the igniter. All the igniters get their power from one spark module that is mounted somewhere in back of the oven. That's why you are able to get all the igniters to spark with only one burner control turned on. This is normal. That is also why you are able to light the burner in question buy turning on another burner. The spark is being provided by a switch that is working. To answer your question: the igniter is removable, but I don't think it's necessary. Cleaning them generally doesn't make them work better. I would check the wiring from the spark module to the burner switch and/or replace the switch. I hope this helps.
Jul 18, 2007 | GE Profile JGSP48 Gas Kitchen Range
GE Profile Spectra JGB920SECSS Gas Kitchen Range Logo
138 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
