Cooktops Logo
Anonymous Posted on Jan 14, 2010
Triple Element does not burn on single mode.
How do I get the top off to look inside at the burner elements?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
118
Points
I ordered a replacement part from Sears Direct and used their schematic for a guide.
Electric schott ceran glass cooktop model number ISE630WS01 right burner not working
Based on your question that the right front burner of your Schott Ceran glass cooktop is not working, here are some steps you can try to troubleshoot the issue:
  1. Check the power supply: Make sure that the cooktop is properly connected to a power source and that the circuit breaker or fuse is not tripped. If the circuit breaker is tripped, reset it and try turning on the burner again.
  2. Check the burner control switch: The burner control switch regulates the power to the burner. Check if the switch is loose, damaged, or defective. You can test the switch for continuity with a multimeter to determine if it is functioning properly.
  3. Check the heating element: If the burner control switch is not the problem, the issue may be with the heating element. Check the element for visible damage, such as cracks, burn marks, or discoloration. If you see any damage, the element may need to be replaced.
  4. Check the wiring: Check the wiring connections between the burner control switch and the heating element. If any of the connections are loose or damaged, this may be causing the issue.
  5. Test with a different burner: If you have multiple burners on your cooktop, try testing the right front burner with a different control switch or heating element to determine if the issue is with the burner or another component.
The above are basic means of troubleshooting, the following below will add more to the solution above;
Check the control board: The control board is responsible for sending power to the heating elements. Check the control board for any signs of damage or burning, and test it for continuity using a multimeter.
  • Check the thermal fuse: The thermal fuse is a safety device that cuts off power to the heating elements if they overheat. Check the thermal fuse with a multimeter to see if it has blown. If it has, you will need to replace it.
  • Check the switch relay: The switch relay is another component that can cause the burner to not work. Check the switch relay for any signs of damage, and test it with a multimeter to see if it is functioning properly.
  • Test the voltage supply: Use a multimeter to test the voltage supply to the burner. If there is no voltage, this could indicate a problem with the control board, thermal fuse, or switch relay.
  • Check for loose connections: Inspect all wiring connections between the control board, switch relay, and heating element. Loose or damaged connections can cause the burner to not work.
  • Feb 05, 2023 • Cooktops
    2answers
    Euro kera
    THINGS TO CHECK:
    the broil element
    is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
    The bake element
    is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter.( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced.Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
    The oven safety valve
    (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
    I offer free advicebcuzGod is so good!
    Surface burners
    are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
    On modern electronic control ranges,the oven temperature sensor
    is the part thatregulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meterbut will need to know the correctresistance of the sensor at room temperature. Remove power from the appliance before performing this test.
    The infinite switch
    on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check foroverheated wires or faulty terminals first.Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
    1. If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.(Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
    1. On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
    1. Set yourmultimeterto ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
    1. Repeat the step above for the terminals "L2" and "H2".
    1. If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
    1. With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
    1. A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
    If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
    Most modern ovens usean electronic control board
    to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
    The oven burner igniter
    commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter.If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve.This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
    http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
    https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
    Jgd8348bdp burner not working
    SEE PICS Or Oven safety valve needs to be checked with multi meter ohms / voltage
    ALSO Test the Burner Heating Element
    The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
    Before testing the heating element, unplug the appliance or shut off the power at the fusebox orbreaker panel to avoid an electrical shock hazard.
    When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
    First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
    Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
    Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity. Test the resistance of the heating element using a multi meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
    To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continui
    1helpful
    I have intermittent problem with two of the four rings - sometimes they work sometimes they don't
    see this causes and proceed for fix it. God bless you
    Surface Element Switch If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
    Surface Element Board If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
    Coil Surface Element If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
    Radiant Surface Element The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
    Solid Surface Element If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
    Terminal Block If a surface element won't work, there may be a problem at the terminal block. The appliance has a power cord which is attached to a terminal block. Over time, the connections at the terminal block can fail and burn open. When this happens, normally all of the surface elements won't work. The solution is to replace any burned wires and replace the terminal block.
    Loose or Burnt Wire Connection If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
    Incoming Power Problem Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
    My Jenn AirCooktop Model CVE3401 burner problems
    The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
    The switch for the dual burner is 12002125, and 74011242 for the single burner.
    The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
    GE Cooktop JP930 surface element not working
    It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
    Electric stove
    if it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
    if single you have a short or a bad switch
    Apr 09, 2008 • Cooktops
    Jenn-Air Electric cooktop
    did you replace the limiter the long rod that goes across the element or just the element everything i can find says that's the culprit
    Top Kenmore Cooktops Experts
    Kolbrun...
    k24674
    Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
