Question about Proview PL 566s 15" Flat Panel LCD Monitor
LCD Monitor Half Screen Pink
I have a 19" Samsung SyncMaster 931a (LCD) and half the screen sporadically turns pink around images and words. The only part of the picture's colors that are pink are the lighter colors. Darker colors look fine.
At first I thought It was my video card because my monitor is under a year old. But to my knowledge if it was my video card a screen shot should show the pink, but it doesn't.
I then thought it was a connection or cable problem. It was using a DVI connection when it first occurred so I purchased a new DVI cable and replaced it, but it still happened. I then switched to a VGA cable and the same thing.
Like I said its sporadic, It works fine some days while others it will happen for hours.
Searching the internet I could not find anyone with the same problem, maybe I didn't look hard enough. Anyone's help would be very much appreciated.
    Genius:
  • 3,587 Answers
Sounds like a color balance issue. Check the menu, do a degauss...and then check for the color temperature (reset for default)..
Got backup?
Posted on Feb 10, 2008
Thin vertical colour lines on half of the screen
Hello, there is a problem with your monitors picture tube. May be it might have been damaged as a result of over power or even because of over use. Just try to change the picture tube or change your Monitor.
Nov 15, 2017 | Samsung SyncMaster 910MP 19" LCD Monitor
Samsung Syncmaster 204bw has a red screen
A red or pink tint to the screen indicates that the back light bulbs are failing and are about to burn out. Its time to look for a new monitor.
Mar 17, 2012 | Samsung SyncMaster 204BW LCD Monitor
Hello, I took apart my system to move furniture around and to clean. When I reconnected everything, all was well except all white areas on the screen have turned PINK! I tried going thru the...
Hi
This is a problem with a high magnetic field hence you need to de-goz the screen. Or leave it un-used for some time and it will be alright by itself.
Maybe when you were shifting you have kept a speaker with big magnet around the monitor thats why this has happened.
Dont worry it will go bad to normal by itself.
Jul 16, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
Screen is Pink what happened?
It can be:
Bad VGA cable, try another cable.
Bad video card, try it on another PC or reseating the card if it is plug-in type video card.
Bad back lamps
Apr 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
Image does not fit screen
Set your setting to "Secondary Screen Only"
As your setting for both screen doesn't seems to be adjusted but you can try turn it off.
Jul 26, 2017 | Samsung SyncMaster 172N 17" LCD Monitor
SyncMaster 932B blinks, then screen goes black
Check all the connections and if they are all right and tight then the monitor is probably shot. The good news is that it can be repaired. It's usually around $50.00 to $80.00 to fix. Good luck!
Aug 29, 2009 | Samsung SyncMaster 932B LCD Monitor
Pink color
check the led back light of your monitor. I you cant do-it-yourself better to go to service center
Jul 30, 2009 | Samsung SyncMaster 920NW Monitor
Screen turns gray with lots of vertical lines with some pink color as well. Happens sporadically.
Make sure that the cable from your monitor is securely plugged into the back of your PC and that the screws to hold it in place are tightened.
Jul 29, 2009 | NEC LCD195VX-BK (Black) 19" LCD Monitor
Proview PL 566s 15" Flat Panel LCD Monitor Logo
358 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
