Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Generic problem for all PC Desktops
ATAPI DVD A DH16A1L not reading blank dvd's
Seanwho on Feb 10, 2008
I re-installed my cd/dvd drive after the DMA turned off. The DMA is back on but now the drive will not recognise blank dvd's (+R or -R). The drive will play dvd movies but when i put in a blank dvd it recognises it as a blank cd on the cd drive (not dvd drive). I have checked the cables in the drive and they are plugged in fine. I have also removed all my burning software and tried to delete the upper and lower filters but their are none there ( I followed the instructions from the HP Compaq website). Any ideas how to fix this??
Thanks
Comments:
Feb 10, 2008
- Hi,
I am pretty sure this is a problem with the OS and inccorect driver. I have checked the driver and it is for a CD drive (off microsoft website), I have found firmware for my drive on the HP website but it is for Vista ( I backgraded my Vista to XP Pro with SP2), so far I can't find a driver anywhere (it exists because I had it before). I have uninstalled the drivers and reset allowing windows to find the device again and re-install the driver. Windows finds the ATAPI DVD A DH16A1L then finds CD-ROM drive and installs the driver for CD-ROM drive (not DVD drive). The drive plays DVD movies but recognises data DVD or blank dvd discs as CD's. The device manager shows the drive as ATAPI DVD A DH16A1L so I am sure if I find the right DVD driver the problem should be fixed. Any ideas where I can find the driver or recover the old one (tried rolling back the driver but it's not there).
Thanks
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Apr 13, 2009
-   I've been in need of the driver for this d*mn thing since i backgraded to xp home sp2. Apparently there's no driver software/firmware available for xp, only for vista. Although, I'll be glad to be proven wrong on this one. Please, someone, I'm begging you. Prove me wrong! (Really! It's a pain in the *ss when you can't write on blank dvds!) -   Guest
Apr 02, 2009
-   +1
Also downgraded from Vista to XP, also have same ATAPI DH16A1L driver.
All looks good but if there is a DVD in the drive XP will not copy files to the drive in order to burn them. if they are copied frist and then the DVD inserted it won't open the drive window. Works fine to read DVD or write CD.
-   Guest
Mar 06, 2009
-   The pc doesn't recohnize the DVD deck. It opens and closes but in device manager there is the yellow question mark. I also get an error 39.-   wilday
Oct 27, 2008
-   my firmware / drivers need updated i think
-   inferno_10
May 15, 2008
-   Identical problem, was working fine until I burned my first music CD through Nero. PC (HP) is barely a week old.-   Guest
Solution #1
posted on Feb 10, 2008
Somewhat Helpful)
rolltape
Rank: Wiz
Rating: 84%, 43 votes
My suggestion are these:
  • Re-install the drivers WITHOUT the burning software installed. Get the latest drivers from the HP website. Make sure that you first go into the Device Manager and uninstall the current driver before reinstall.
  • Make sure that you enable the drive to be used by all users.
  • Login to the user you want to. Insert a blank DVD, and see if it works. If it doesn't then continue the instructions.
  • Check to make sure the disk drive letter does not interfere with another program or drive (such as a virtual drive on the standard user's account)
Good Luck.
Comments:
Feb 10, 2008
- Quick Question; When you backgraded Vista to XP, did you re-format your hard drive? If you didn't there are most likely problems with vista drivers colliding with XP drivers, even though vista is gone. If you didn't reformat your hard drive, now would be a good time to do it. Just make sure you back up all your important files (NOT drivers).
However, if you did reformat, then I'm gussing when windows found the driver, it found the wrong one and installed it. Here is a link to google to search for driver software: http://www.google.com/search?hl=en&safe=off&q=%22ATAPI+DVD+A+DH16A1L%22+%2Bdriver+%2BXP&btnG=Search
The last thing I can think of is it being your XP driver burning software. I had this problem yesterday. Try searching for a free DVD burner software online (not the one that came with the DVD drive). See if that will work.
Was this helpful?
Yes
No
Related Problems
I tried to start my t6520, light turns on fans run hard,...
No boot up/power-changed power supply. There is light on...
When I push the ON button on this computer, nothing happens....
when starting a burn cd/dvd drive is opened and cd is...
Can you Help with these PC Desktop problems?
I need to know how to program tax...
Solve
I need to know how to program tax rate. for casio pcr 265
<Windows...
Solve
computer bots with this system32hal.dll
Cannot use songs bought on itunes on...
Solve
Cannot use songs bought on itunes on windows moviemaker... says I dont have the proper codec. Dell... (More)
how do you connect dell inspiron...
Solve
i can't connect my built in web camera. i need to know how to connect it so i can use it.
8 Other Users Have The Same Problem - Continued
Comment by TrevorT2, posted on Apr 01, 2008
I have a fairly new HP with the same ATAPI DVD problem. I kept Vista Home Premium installed, and was using the dvd burner and it was working fine for months until I tried to burn a CD-R with it for Music on 3/18/2008. Now it will not read any DVDs with Roxio Easy Media Creator, or free InfraRecorder. There are no errors in the device manager, but it doesn't detect any DVDs or CDs in the drive now.
I have rebooted, uninstalled the DVD drive in device manager and reinstalled it using the existing driver. I will try finding a new driver when I get home. Not sure if any automatic updates changed things, or the fact that my free CA antivirus program from Time Warner seems to have an old signature file has anything to do with the change.
Comment by L2THE-Y, posted on Mar 30, 2008
Exactly the same problem. New PC, used the dvd burner once, on playback on dvd player the dvd skips and pauses. Tried to burn another copy at a slower burn rate and dvd drive refuses to read blank dvd, says it is a blank cd. Have tried to find drivers for the dvd drive for XP but to no avail. Any ideas guys?
Comment by BintangBuzz, posted on Mar 21, 2008
I have the same problem, I have 3 DVD'RW's doing the same thing. The not reading the blank DVD started after I crashed this computer. When I reloaded the system XP will only load CD divers and not DVD drivers. This was an external DVD'RW Lite-on
Then a month back I loaded a DVD decrypter on the other computer and some other software on the computer and bang no more blank dvds reading in that machine to. I have even replaced the CD-RW with a second DVD-rw and we have the same problem. They are both LG.
So far I have reformated 1 computer (with the external DVD) but I have not regained the drive.
I also have lost all USB 2.0 capabilities which are not fixed by the XP update
Sponsored Links
Describe your Computer problem:
Select a Category:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 2826
Experience: I have yrs of experience dealing with many situations.
Ask Me
Find more PC Desktop Experts
Top Computers & Laptop Repair
(562) 366-0079
On-Site Service 24/7. Home & Business IT...
RTS Technology Group, Inc.
(330) 502-6853
Instead of lugging your computer into a shop and...
PC Desktops
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
