Question about LG 42PC3D 42 in. Plasma Television
Lg 50 " plazma red pixels appering around top of screen
Red pixels are showing on top part of television when it on for more that two hours. Is it overheating or is the television shot. Any solution ideas?
  • shannamakeup Mar 16, 2008
    LG's 42 inch Plasma TV.  mine is doing the same thing. Except my red pixels are all in the center and lower left side? I've only had the TV for about 2 yrs! What can I do about this!
  • 109 Answers
The actual problem is some of the components on some of the boards are showing signs of age (some of the values are changing slightly) this can be compensated for by adjusting your voltages (such as va & vs ) this take a little tech knowhow. or you can replace the y sus board but adjustments are necessary whenever replacing y or z control boards. hope this helps. i may know where to get boards if you need them.
Posted on Mar 28, 2008
    Problem Solver:
  • 19 Answers
Try josheling the TV with the help of someone (do not drop!). There are gasses that settle and sometimes this will work, as it did for me on my 52". Depending on the age, it may just need to be recharged.
Posted on Feb 10, 2008
My LG Plasma 50PK550 shows 1 or 2 vertical lines, 1 pixel wide, with bad color : black, gray, white and blue are correctly displayed, but Red/Green colors are not rendered. I suspect a problem of Chroma...
Your idea should be correct I assumes. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Screen-shots to defective plasma screen is given in detail with fault causes. You can compare it to that of your TVs' and can make sure.
Oct 20, 2013 | LG 50PK550 50 in. TV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
LG 50 Plazma screen is dark pink sometimes goes to normal
Might be to some loose interconnection cables. Seek tech support.
Jun 09, 2012 | LG 50PS60 50 in. Plasma HDTV
Hello. My LG plasma 50pc3d has had red pixels jumping around whenever there is black on the screen, but has always cleared up. Today a vertical red line appeared, 1pixel thick, running from top to bottom....
Pixels on a plasma TV are from the zustain boards. You might have one or both of them about to go out. Horizontal lines are most likelly one of your buffers or the screen itself might be going bad. You can buy the sustain boards by part number that you can get from the board itself from www.interliquidparts.com
Jun 04, 2011 | LG Televison & Video
Dots on screen
The snowy dots and dots are typically from a poor signal going into the TV.
If there are colored pixels that stay lit all the time (like a red pixel and never goes away) and for any input, that’s called a stuck pixel.
A stuck pixel may be caused by a bad Y-Sustain, Y-drives, Z-sustain, and or a bad plasma panel.
Good Luck.
May 22, 2010 | LG 50PX1D 50 in. Plasma Television
Red/pink shades in dark areas happens only 6ins down from top
Sounds like you have a cap that leaky or a ic thats getting hot,
if you want to try and fix it yourself get a can of freeze it
http://www.chemtronics.com/products/product.asp?id=78
and when the problem appears spray the can on each (ic or cap) part till the problem goes away.
Dec 03, 2007 | LG DU-42PY10 42 in. Plasma HDTV
Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Aug 30, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
LG 42PC3D 42 in. Plasma Television Logo
465 people viewed this question
