Question about Sony Cyber-shot DSC-W55 Digital Camera
Sun disk My memory card for my camera says it is locked...how do i unlock it?
  • aGriff Feb 10, 2008
    Actually there was a small piece of gold that slid up and down...moving this from one position to the next fixed the problem...thank you very much
  • Anonymous Mar 23, 2008
    I have the same problem, and it doesn't help unlocking the "memorycard itself" not even if I change to another card
    Problem Solver:
  • 19 Answers
Most cards have a small pice of plastic on the end that allows you to lock/unlock. Pull the card out and slide to the unlocked position.
Posted on Feb 10, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How do I correct memory card error?
If it is an SD card then they have a very small lock switch on the side Set it to unlock.
Aug 20, 2015 | Cameras
How to remove sd card write protection
Take your memory card out of the camera and switch the position of the "lock" tab. One position is for "locked" (i.e., "Write Protected") and the other position will allow the card to be written to (unlocked). Some cameras have image protection built into the on-camera software and you may need to configure this there.
Feb 18, 2014 | SanDisk Electronics - Others
When I try to take a picture it says card locked. One disk works fine - other disk CVS SDHC gives me this message
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jan 30, 2011 | Samsung DualView TL205 Digital Camera
I put my memory card in my card reader and connect it in a computer to delete the pictures in it but everytime I attempt to delete it, it says cannot delete PICT0005, the disk is write protected. Remove...
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Jan 07, 2011 | Cameras
I have the samsung s630 and i have taken some pictures on it before i got a memory card. i want to save them to my memory card, but when i insert the memory card those photos wont show up. how do i get...
If you remove the card from the camera and connect the camera to your computer with the USB lead, you should see the camera's internal memory as a disk drive on the computer. If there is a memory card inserted, you will see that memory instead.
Unlocking individual pictures is done with the same function that locked them. It is probably on a menu available when you are viewing the pictures on the camera.
Oct 20, 2010 | Samsung S630 Digital Camera
Sd card locked showing on camera
dear sir,
remove the memory card,and just push the push button at the upper side of the card which allows the card to lock and unlock.....kindly unlock it and put inside camera and your flash disk is no more write protected...
thank you......take care......
Oct 08, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
Camera says memory card locked when turned on ,i want to delete card to use again contents already saved on disk
May 07, 2010 | Casio Exilim EX-Z750 Digital Camera
Memory card locked
Sounds like the 'lock' tab on the memory card has been moved to the 'safety' to prevent you from re-writing your card accidentally
Fix it by:
1 remove memory card from camera
2 look for the very little tab/switch on the front of the card
3 slide it to the unlocked position (opposite of now)
4 put it back into camera...should now allow you to take pictures
if the tab/switch is missing do not dispair...
-use a small piece of clear tape to cover this 'tab/switch' opening
-this is the same concept as cassette/vhs/ 5 1/4" floppies...removing the 'tab' to lock it
Sep 10, 2008 | Samsung Digimax L830 Digital Camera
Memory card locked!
There is alittle slide on the memory card.
Take it out. Look for it. Depending what you have it may be yellow, look on the left. If it's down, slide up and it will be unlocked. :)
Apr 19, 2008 | Canon PowerShot A520 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
63 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
