Question about Toshiba TZ50V51 50" Rear Projection Television
Accidentally changed height somehow while using remote, now "squeezed"
I somehow got a small display of a green "hit" and some numbers on the screen a while ago, and it appeared to shrink or expand the height of the screen. I thought I had it back where it was, but now all I have is a squeezed down version in the middle of the screen. It's a little taller in the middle than the sides, but very odd. Any idea how to get this back to normal. Have tried the "reset" feature, did nothing to change. I can;t figure out how to get that one screen back, so I can expand the heighth again.
-Any ideas
  • Toshiba Master
  • 8,617 Answers
Ou will need to adjust that via the service menu. Toshiba has 2 ways to access it on various models I will post them both. first way
1. TV turned on
2. Press 'Mute' button on the remote.
3. Press 'Mute' button on the remote again and hold.
4. Press the 'Menu' button at the TV.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the item.
5. Write down the old value of the item before changing.
6. Use Volume up and down adjust the value.
7. When you have made all the adjustments you want turn the set off to exit.
Posted on Feb 10, 2008
  • Sonny Berry
    Sonny Berry Feb 10, 2008
    Here is the alternate Toshiba method
    1. TV turned on
    2. Press 'Vol down' button on the set.
    3. Press '9' button on the remote and hold.
How do I fix a shrinking screen?
Hi Carole, please give details of make and model. I will then have something to work on.
Sep 05, 2015 | Televison & Video
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Laptop display problems
Hi Neela
Thank you for your query
Please try the following
1) Right Click in the middle of the desktop
2) Click on Properties
3) In the display settings box that appears click on the tab that says settings
4) The settings can be adjusted from here i..e screen resolution and colour quality, the display adapter can also be checked to ensure it is correct i.e. yours should be something like nvidia etc etc
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 24, 2010 | Dell Inspiron 1420 Laptop
Philips Magnavox Video Shrinks over and over
If you have the following symptoms check the site www.TvRepairKits.com . They have a repair kit for this problem.
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Works on the following Philips Magnavox sets with chassis number
PTV835, PTV836, PTV840, PTV841, PTV842, PTV843, PTV844, PTV847, PTV853
Or if your Model number is...
50YP43C101,50YP43C102,50YP44C101,50YP44C102,50YP44C103,50YP44C104,55P9161001,55P9161002,55P9161003,55P9161004,55P9271001,55P9271002,55P9271003, 55P9271004, 55P9271005, 55YP43C101, 55YP43C102, 55YP43C103, 55YP43C104, 55YP44C101, 55YP44C102, 55YP44C103, 55YP44C104, 55YP45C, 60P9161001, 60P9161002, 60P9161003, 60P9161004, 60P9271001, 60P9271002, 60P9271003, 60P9271004, 60P9271005, 60YP43C101, 60YP43C102, 60YP43C103, 60YP43C104, 64P9161001, 64P9161002, 64P9161003, 64P9161004, 64P9161005, 64P9161006, 64P9271001, 64P9271002, 64P9271003, 64P9271004, 64P9271005, 64P9271006, 64P9271007, 9P5031C101, 9P5031C102, 9P5031C103, 9P5034C101, 9P5034C102, 9P5034C103, 9P5040C101, 9P5040C102, 9P5040C103, 9P5040C104, 9P5044C101, 9P5044C102, 9P5044C103, 9P5044C104, 9P5511C101, 9P5511C102, 9P5514C101, 9P5514C102, 9P5531C101, 9P5531C102, 9P5531C103, 9P5534C101, 9P5534C102, 9P5534C103, 9P5540C101, 9P5540C102, 9P5540C103, 9P5540C104, 9P5544C101, 9P5544C102, 9P5544C103, 9P5544C104, 9P6031C101, 9P6031C102, 9P6031C103, 9P60349101, 9P60349102, 9P60349103, 9P6034C101, 9P6034C102, 9P6034C103, 9P6040C101, 9P6040C102, 9P6040C103, 9P6040C104, 9P6044C101, 9P6044C102, 9P6044C103, 9P6044C104, 9P6440C101, 9P6440C102, 9P6440C103, 9P6440C104, 9P6440C105, 9P6444C101, 9P6444C102, 9P6444C103, 9P6444C104, 9P6444C105, PV5571C101, PV5571C102, PV5571C103, PV5571C104, PV6071C101, PV6071C102, PV6071C103, PV6071C103, PV6071C104
Dec 12, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 60
which chip did you replace? and what is the model number of your set?
Aug 29, 2008 | Philips Magnavox 9P6034C 60" Rear...
800 x 600 resolution makes desktop small with inches of black surrounding it
I have a Dell Inspiron 8100 and I believe the combination is Fn+F7 to expand the screen. Must be pressed at bootup..
Jun 21, 2007 | Dell Inspiron 8100 Notebook
Picture Shortens, Converges, eventually the set shuts off - $50 for Correct Solution
Open the TV amd turn it on in a position you can see the picture, possibly through a mirror. Now gently tap all of the metal heat sinks on the circuit board until you find the one that is sensitive it will have a small chip mounted vertically on it, with probably like 7-10 pins. The number on the chip will most likely be an "LA****" number. Now turn the circuit board (UNPLUG FIRST) over and resolder the pins. This is your problem 99% of the time. Be very careful there is High Voltage inside this TV.
Apr 26, 2007 | Zenith IQB36B42W TV
Toshiba TZ50V51 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
