Question about Vacuums
Reginna Steemer Carpet Cleaner- older model- will not suck
Regina Steemer Carpet CLeaner dual speed will not suck up water.
  • 27 Answers
Check for clog in motor intake. Take off the tank and look up into the motor. There will be a round tube with a plastic grate.
Posted on Feb 23, 2008
Not sucking up the water
Look at the pickup nozzle to see if it's plugged up. There is a flapper valve that closes when the tank has too much water in it. Make sure it opens after you dump the water out.
Aug 14, 2016 | Bissell Carpet Cleaner Powerbrush Deep...
Was sucking up cleaner and water on carpet and suddenly there was smoke and the machine shut down. Is it broken for good?
Patsy,
Depends on what went wrong. How long have you had it? Do you know if it might still be under warranty? Check this link to see if you can find someone close to you that could look at it. for you.
Service Center Locator
Aug 10, 2015 | Hoover F7412-900 SteamVac Dual V Widepath...
I have a Bissell ProHeat 2x advance carpet cleaner . It stop sucking up water. How can I fix it?
First check your filters. The Customer User Guide says to clean them after each use. There's two: The Water Tank Cap filter (looks like a screen) remove it, clean and reinstall, and the Flow Indicator: Turn the Flow Indicator Cap counter-clockwise and remove. Remove the rotor and under it is the filter. Remove, clean and reinstall in reverse order. If that didn't do it call Bissell Consumer Care at -1-800-237-7691 Hope that helps.
Feb 13, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I need an owners manual for my regina steemer pro model: rg4152-1. it is a 7 amp cleaner. where can i find one?
Regina is now part of the Dirt Devil, your nearest dirt devil dealer should be able to assist you.
Oct 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The bissell proheat turbo carpet cleaner is not sucking up water.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jer
Jun 08, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Cleaner not sucking up dirty water.
try stripping it down and cleaning all parts and filters .some cleaners use a safety 'ball' to stop water getting on the motor is this stuck it should slide up and down a small track in a tube..good luck hope this helps farr64.
Apr 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Proceedure?
You release the water on the reverse stroke, and the machine will pick up in that same stroke. You push the machine forward to position it and pull back slowly as you pull the trigger to release solution and clean the carpet.
Feb 01, 2008 | Regina RG3100 Vacuum
Vacuums Logo
404 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
