Question about Toshiba TZ50V61 50" Rear Projection Television
I need to replacement the screen ?how wand where can I get it?
Screen replacement
  • 84 Answers
Are you a service tech? if not, don't even try it. you'll regret it.
C-Dog
Posted on Feb 11, 2008
Husky 1800 Pressure Washer motor will not turn off when wand trigger is released
I think you have one of two things going on hear, an overpressure problem or a carburetor issue with the engine.
Jul 25, 2017 | Husky Garden
Chimbali m1 water
Maybe the machine needs a cleaning. White vinegar usually works pretty well.
Jun 13, 2014 | Espresso RMI La Cimbali Espresso Machine
My pressure washer will not gain pressure. What will cause this problem?
Make sure water supply is ok, make sure screen is clean, try all the different tips, make sure they are seated correctly. Water should come out of the hand wand even if not under pressure, this shows the wand handle is working, so if water come out it's not the trigger handle. You can remove the wand hose, wand handle and see if there is any obstructions also.
This can also be a stuck check valve, you might need to have it serviced.
Apr 12, 2013 | Garden
Do you need to vacuum out the lint & how
There are several ways to remove lint from a dryer and vacuum is 1 option. Put the skinniest attachment on the end of a vacuum, pull out the lint screen and put vacuum hose with attachment as far down as it will reach to pull out excess lint that the screen didn't catch. Another, simpler option is to get a wand especially designed for removing lint from your dryer. It cost about $5 in most stores and has bristles on it. You remove the lint screen and work the wand by hand up and down with the lint clinging to the wand. Either way, it's a very good idea to do this operation every few months.
Apr 08, 2011 | Dryers
My power mate keeps losing power. As I am vacuuming, it surges off and on. The rest of the vacuum works perfectly fine. help!
Remove the wand from the telescoping pole, and look at the two holes in the wand where the electrical connection is made between the wand and the pole. You may see corrosion, which will cause the connection to be flaky and the power assist to surge on and off.
In any case, a good bet is that the wire harness in the wand needs replacing. It's about $15. (P/N KC37GBZTZV06) You'll have to take the wand apart - 3 screws and some judicious prying - to replace it.
Dec 28, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
Hi its Darran at Dyson.
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Wand in stowaway dyson is hard to extend. Seems like u have to pull 3 clips from grooves in 3 rings around wand to extend and shorten wand which is a struggle
Hi there, you should just be able to hold the telescopic wand in one hand, press the button and pull the whole length of the wand out to its fullest position.
If the telescopic wand on your particular Dyosn is very stiff, you may need a replacement.
Your machine may still be under guarantee or warranty. If this is the case, please contact Dyson directly on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dec 27, 2009 | Dyson "Stowaway" Canister Vacuum Vacuum
I have a Breville ESP6 Espresso Machine which needs a new steamer wand. The seal on the screw in part at end has gone and the thread is gone too. Water spurts out between the wand and the screw in knob -...
The wand is relatively easy to remove. Thing is whether you have the right tools. If you can find stubby phillips and flat screw drivers, the job will be much easier.
You first have to remove the trim that surrounds the pod and where it covers part of the wand.
The wand is held down by a flat-headed short screw. It might take a few tries to remove this screw due to calcification over the years. Once removed, the wand should just slight out. Check if the o-rings need to be replaced as well.
Mar 05, 2009 | Breville ESP8XL Espresso Machine
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Dec 05, 2008 | Delta Model 470: Signature Kitchen...
Toshiba TZ50V61 50" Rear Projection Television Logo
149 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
