Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Battery/battery charger whenever i plug the battery charger into an outlet, the red light will come on for less than a second and then go off. the light does this almost every time i plug it in!
  • 374 Answers
Sounds like you're having a problem with your charger. Send camera, battery, charger and power cable into repairs and they can check it for you.
Casio America Repair Center
Atten: NP20 battery
570 Mount Pleasant Ave
Dover, NJ 07801
Include a copy of your sales receipt with your contact information so they can send it back to ya.
Posted on Mar 30, 2008
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
Charger not working
When the red light is on it is to indicate that the charger is getting power from the wall outlet. If there is a second light that normally comes on Green when charging pay close attention to it when you first plug the charger in. See if it blinks even once then turns off. If it does that means the charger is not seeing any battery voltage at the plug that goes into the chair. If the green light does not blink at all then it usually means the charger is defective. Also most wheelchair battery chargers will not charge the batteries if the chair is to dead to even turn on.
Apr 12, 2015 | Health & Beauty
When I plug the unit into the AC charger I hear a
w+pnt0gwwvrvgaaaabjru5erkjggga=
I would check battery, it may not be good, If you need battery look online it will be less expensive than buying from mfg.
Oct 27, 2017 | Cobra Electronics Cobra Jumpstarter Air...
Nokia N900 not turning on or charging
not turning on. red notification light showing
May 14, 2010 | Nokia N900 Smartphone
Cannot recharge using car recharger - no red light showing on charger plug in. Do not seem to have been supplied with a mains adaptor. Help Thanks Paul
Check the fuse in the car charger by unscrewing the tip - the red light should be on whenever it is supplied with power. Otherwise check your vehicle fuse to the 12 volt outlet (or try another device in the outlet).
Nov 04, 2009 | Garmin Nuvi 660 GPS Receiver
18 volt milwaukee batteries
You could try another battery if you have on(they only last for so many charges) or your charger could be bad. Try plugging it in to another outlet. Good Luck
Oct 15, 2008 | Milwaukee 6310 22 18 Volt 6 1/2 In....
On my camera the battery charger light is blinking and the battery is not charging
Before you get creative and directly plug your batter into an AC adapter, try something much easier first. I have the same problem with my Olympus 770SW batteries. As silly as it sounds, the charger will only work in a select few outlets in my house that I found by trial an error, actually pure frustration. I suggest, go around your house and plug the blinking charger in all the outlets and see if you find one that works. That sounds a lot less shocking than solution 1 and 2 now doesn't it? Good luck!
May 23, 2008 | Cameras
Turn on problem
your gameboy is completely screwed up so get a new one or buy a ds
Jan 27, 2008 | Nintendo Game Boy Advance SP Console
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
