Humming from speakers
My speakers humm but once the dab is disconnected the system is ok the system is 4 seperates connecting with a computer like ide cable and only 1 power suply.
hitachi ax-m140
  • 4 more comments
  • packard3545 Feb 10, 2008
    WHEN THE DAB IS DISCONECTED I HAVE NO PROBLEM
    it only humms when dab is connected 1 power suply for all 4 stations connected by a ribbon cable ?
    confused bad ground wires ?
    did not know if was worth taking to repair seems like this is a common problem with this model
    speakers are humming all the time however if i disconnect dab it is ok they even humm when listerning to cd (do not have tobe using dab for them to humm)
    yes even moved to mate house and still have same issue
    ill have to see if i can get it modded or sell it ?
    Master:
    Sergeant:
  • 440 Answers
Bad grounds wires usally will do this
Posted on Feb 10, 2008
  • 2 more comments
  • nick helpap
    nick helpap Feb 10, 2008
    not sure then
  • nick helpap
    thought u were talking speakers humming
  • nick helpap
    did u cheak wires heavey gage to from amp to speeakes red on red blakc on black ect pluged into a good grounded power strip
  • nick helpap
    ya like u said might just be that unit doing it
Tv and speakers buzzing noise
If the hum is a low note continuous hum, its at 'mains' frequency. The power cables to the unit (or inside it) are getting too close to the cables that carry sound signals to the center speaker. The mains power naturally hums and if mains wires are near to audio kit wires they pick up this sound and play it through their system/speakers. Check the wires to and from it make sure the connections are good and firm. Seperate these wires by at least one inch from any power cables, use tape to hold them down and away from each other.
Dec 15, 2013 | Bang and Olufsen Audio Players & Recorders
I have the JBL speakers which are really decent but i want them to be as loud as possible! if i plugged in my logitech speakers into one of the inputs that i would normally put one of my little speakers in...
It should be OK BUT if the JBL and the Logitech are plugged into different mains outlets you could get a hum from one or both sets of speakers. This hum is caused by an earth loop when the speakers are connect to different mains outlets.
The fix.
Connect a power board to a mains outlet and then plug the mains connections from both set of speakers and computer to this power board.
Oct 25, 2012 | JBL Encounter 2.1 Computer Speakers
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
I get a humming sound when the ipod is attached,
the hum comes from three possible sources, the power unit can cause it before failure, the amplifier which can effect one or more speakers or the interface board between the other two, the interface board and the power board are known problems to b and w, so if you have not already contacted service at b and w, then do so.
May 15, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Bad Humm out
First disconnect all inputs. If hum is still there, PROBABLY the filter capacitors have gone bad. Replacement is the cure.
IF there is no hum without any inpout cable connected, there is a ground loop and either the ground at the inout connector is broken, or your cables and guitar may have a problem.
Nov 15, 2009 | Marshall Amplification Marshall MG250DFX...
Cd player not working
Hello
Replace the laser pickup unit along with its connection wire to main board. OK.
Apr 08, 2009 | Sony CMT-NE5 CD Shelf System
Humm
where is the ground wire from the turntable connected to ? Ensure that is is connected to the phono pre-amp's ground.
Is the turntable sitting on top/near any other equipment ? Try changing the position and see if the hum reduces. If yes, then it is likely that it is picking up hum from a mains transformer.
Aug 21, 2008 | Aiwa PX-E860 Turntable
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
230 people viewed this question
 Grubhead
Grubhead
