Question about HP Officejet 6310 All-In-One InkJet Printer
Fax recption is there any software that can use an hp 6310 all-in -one to recieve a fax and show it on the computer first without automaticly printing it first
    Genius:
  • 3,587 Answers
Not that I know of. If it ain't on the printer management software suite, then there are few outside developers for that option. Did you check the settings on the Fax receive to see that you can save to a file, instead of outputing it directly?
Got Backup?
Posted on Feb 10, 2008
I recieved a fax a few months back that i cannot find it , does the the hp 6310 all in one have a memmory log so i can access the document again?
You can give it a try, hopefully the printer should be able to print the fax log if it hasn't erased it.
Press Setup Button on printer front panel
Scroll to Print Report - Press OK
Scroll to Fax Log - Press OK
Check the fax that you had received on the date and press ok or it may print the fax log present in the printer.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 19, 2011 | HP Officejet 6310 All-In-One InkJet...
I do not have the floppy disc to install my 6310 printer,my printer will not print
Hello sir; You don't have to worry about, if your computer with wizard software, click "start" on your computer, then go to setting, click on printer & fax, select adding then follow the instruction to finish installation.
Jan 29, 2010 | HP Officejet 6310 All-In-One InkJet...
HP 6310 print problem-prints first 10 lines OK then next 10 are on a new page etc. Re-booting PC fixes problem.
Please check the Page selecton
check the page setup click on file -click on pagesetup
Press Ctrl+P
Check the layout settings
Check print priver if print privew is ok then its software issue
Check the printer drivers
DRIVERS HP Officejet 6310 All-in-One Printer
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
Can I receive a fax already recieved
With a computer: The software or utility that views your faxes should also be able to print them. (This may not always be the case).
Without a computer: You could try making a copy of the fax.
Dec 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Fax services not available from Computer
I work with Hp
It is not that you cant fax from the solution centre
but the fact that windows vista has an updated version of the registry which
will not allow faxing from the pc unless you have windows Vista ultimate.
Im not trying to blame Microsoft instead of Hp but I have taken calls where customers cannot fax using hp solution centre in vista and I started checking the registry and there is one component in Windows Vista Ultimate that is present which willl allow you to fax but This same registry entry is not there in other Windows Vista's.
That is why I prefer using windows Xp rather to Darn Vista
Jun 19, 2009 | HP Officejet 6310 All-In-One InkJet...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
