Question about Canon EOS Rebel K2 35mm SLR Camera
Shutter display problems
The shutter numbers on the LCD screen does not show right???
    Scholar:
  • 85 Answers
I hope if the camera set for auto then there would be no speed display
If the batteries are good then the LCD panel should be given attention
Posted on Apr 02, 2008
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
My lcd screen will not show the picture. The
First try pressing the DISP or DISPLAY button to make sure that you didn't accidentally turn off the LCD. But if that's not the case...
Try taking and downloading a picture taken while the screen is blank. Is the picture also blank? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Read the users comments there also for more tips.
Jan 31, 2010 | Canon PowerShot SD1000 Digital Camera
Camera shows no image through the viewfinder or on the lcd screen.pressing shutter button will actuate the camera, but only image is of a black box.using the display button to turn off the lcd does not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 18, 2009 | Canon PowerShot S3 IS Digital Camera
When I put on my camera,the screen doesn't display but I can take pictures alright and view them from my computer.What might be the problem? I gave the camera to my son some time ago for excursion and it...
you are using M853, Right?
Turn On the camera then try to press the menu button or review button if the picture or options will not show up it means the LCD is defective, But if your able to view the picture and the menu settings displayed On the LCD ther might be a problem On the shutter or on the lens itself.
Yu may call tech support toll free 1 800 235 6325 ext 12 and you may request to send you camera for repair
Nov 13, 2009 | Kodak EasyShare M853 Digital Camera
LCD screen stays dark
I have the same problem and very frustrating! The camera turns on by won't show anything (totally black) in the camera mode. The menu still works. If I take a picture the display is black and shows black for it in the display mode model as well. Tried everything that I can think of but nothing helped. (Taking out the batteries and reinstalling, switching the mode from display to camera and back, stepping through each mode option, stepping through each menu options). The last option worked once but won't work later on. From this forum this seems to be a common problem with this camera. Guess won't buy another camera from Canon any more. I bought a camera (non-digitals SLR) from Canon before and was very happy with it for over 20 years. Thought Canon had the right thing in camera. This problem made me think twice when I buy another camera in the future. Perhap Canon is not as good as I thought. By not fixing the known problem, they are ruining their reputation.
Jul 27, 2008 | Canon PowerShot A610 Digital Camera
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
Won't Take Pictures
contact nikon they know about the problem and will fix it for free
Sep 02, 2006 | Nikon Coolpix 5700 Digital Camera
Pentax Optio 555 LCD screen blank problem
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty. I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
Sep 08, 2005 | Pentax Optio 555 Digital Camera
Digital SLR "r06" (or other number) in LCD display
During shooting, or when the shutter-release button is pressed halfway, the number of images that can be stored in the memory buffer at current settings is shown on the exposure-count displays in the control panel and viewfinder. "r06" indicates that six images can fit in the camera's buffer, "r08" would indicate eight frames. Any other number could be displayed as well.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Canon EOS Rebel K2 35mm SLR Camera Logo
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
Are you a Canon Photography Expert? Answer questions, earn points and help others
