Question about Technics SL-1200 Turntable
Pitch LED not working
Hello all, I''ve got an annoying fault where the Green pitch LED will not switch on when the pitch is locked (Centre of pitch slider), new slider fitted & new LED fitted but still no Joy, the pitch slider works OK & the speed remains stable, any ideas please! Barry
  • 515 Answers
LED probably burned out, or installed reverse (+/- reversed) - Or, you installed a clickless (MK3/MK5) pitch control in an MK2 turntable.
Did you do this yourself? Or did you have this professional done? If professionally, and the LED does not work, ask for your money back! This is electronics repair 101!
If you did this yourself, then more than likely you installed the LED backwards. The longer lead is the positive lead. If the LED did not burn out, you might be able to just remove it and switch it around. If it does not work, then it probably shorted (more than likely). Also make sure that none of your solder is touching. This could cause a bad short to your entire turntable. So you want to becareful.
If you need any further assistance, feel free to give our service dept a call. We are masters with the 1200s, and fix over 300 a year! 1.866.668.1596 ext 1
- TERMiNAL OPTiC
www.DJPROLAB.com
Posted on Apr 30, 2008
How big of a role do green issues such as engery eficiency,carbon footprint play in the value proposition that you pitch to prospective customers when they are looking at upgrading their data centre
I personally never pitch anything as Green but I do pitch budgetary savings for new technology based on less power requirements and cooling requirements. I keep it focused on their business and not on things they may not care about at all.
Mar 21, 2017 | The Computers & Internet
Recently purchased used Panasonic SL-HM42 turntable. Works, but turning a little slow on 33rpm (30-31rpms) says DC Servo System on the front. Don't see any set screws on bottom. would like to get platter...
How to tweak the playback speed on Panasonic SL-HM42 turntables
You will need:
  1. 1x small Philips screw driver
  2. 1x small flat-head screw driver
  3. An ear for correct pitch and a little bit of DIY skill!
Step 1 - Remove the wooden base plate
After ensuring that you've removed the the rubber turntable slip mat and securely docked the turntable arm, carefully flip the turntable over onto its lid to expose the wooden base plate, as per below.
Using the small Philips-head screw driver, remove the screws holding the wooden base plate in place, then gently lift the base plate off the turntable.
Step 2 - Expose the pitch adjustment screws
Once the wooden base plate is removed, you will see the speed-controller circuit board on the right-hand side.
To expose the the two speed/pitch-control screws, firstly remove the screw holding the speed-controller circuit board in place, then gently lift the circuit board up on the free side.
Step 3 - Correct the turntable playback speed and pitch
The easiest way I found to correct the playback speed was to flip the turntable carefully back into the original position, allowing the speed-controller circuit board to hang free as shown below.
Next, play a record that you know well and are able to tell when the speed/pitch is correct (assuming you have an ear for correct pitch, that is!), then at the same time using the small flat-head screwdriver, gently turn the speed adjustment screw(s) to adjust the playback speed up or down until the correct playback speed and pitch is achieved (or at least until it no longer annoys you ;).
Turning the screws clockwise (to the right) will increase the speed/pitch, and anticlockwise (to the left) will decrease the speed/pitch.
NB - Both screws allow for fine pitch control, so if the second is already at maximum speed, you can use the first screw for additional speed.
Step 4 - Reassemble the turntable again
When you're happy with the speed of your turntable, remove the record, the mat again & locking the turntable arm, replace the screw holding the speed-controller circuit in place (as per Step 2) and then finally replace the screws holding the wooden base plate, as per Step 1.
Happy listening!
Aug 29, 2013 | Audio Players & Recorders
Pitch control doesn't work
Make sure that the "Pitch" button is turned on (LED is lit) before trying to change the pitch. If it is, make sure that it's not disabled in the settings.
May 18, 2012 | Numark CD MIX 1 Integrated Dual CD Player...
I own a SL1200 MKII and when the light "turn on" in the pitch control slider (green LED) the speed is not correct (big dots on platter move slightly) .Could you please give me some tips to solve...
Use the slide on the pitch control to move forward or backward until the dots stay steady. If it is a little old the quartz control won't work as well.
May 13, 2011 | Technics SL-1200 Turntable
Hello icant change settings of my button pitch and font..my printer is epson fx 2175..i had search that the problem is Font and Pitch lock mode..how to unlock it?
switch on the printer while u holding the pause button and leav it aftre 7 seconds it will print the default setting page.later on you can change it according to the paper setting.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 27, 2010 | Office Equipment & Supplies
Pitch wobble 1210
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do technics turntable servicing
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Apr 23, 2010 | Technics SL-1210 Turntable
Pitch adjust doesnt lock between 0% and +50%
There is a chip in the unit called a
phase lock loop ,( P.P.L )its use as station loc
for stereo turner. But the same applies.
Its drifting and unable to hold/lock
the signel is noisy that its trying to
lock on to (open ground) or the VCO
is out eather way it probley needs
to be replaced.
Hope that help a little
Jun 30, 2009 | Stanton STR8-150 Turntable
Pitch and Strobes
There is nothing wrong with your turntables. The Strobe dots are only a guide to give you an idea of the speed your platter is rotating. Nothing more, nothing less. The pitch control decal is not 100% accurate, it is simply a guide to tell you where the 6% position lies, 3.3%, etc.
As long as the quartz lock function works, and the large middle strobes are nice and solid, and do not move, your fine.
You can check out these videos for more insight into these wonderful turntables:
http://www.DJPROLAB.com
- Optic
Digital Analog Therapy
www.repairny.com
www.1200s.com
Sep 19, 2008 | Technics SL-1200MK5 Turntable
Pitch slider not working
lol just select pitch and press plus or minus to the desired pitch range and if you want to take off key lock just press keylock till you dont see the keylock symbol.
Jan 10, 2007 | Nu Mark AXIS 9
Technics SL-1200 Turntable Logo
430 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
