Question about Samsung ML 2010 Laser Printer
On line/error light
"on line / error" light-red
  • 2 more comments
  • Simon Kay Mar 26, 2008
    when i swithch on the printer, the 'on line/error' light will be on immediately with Orange color (with a little sound on, like machine on, then immediately off), then Red, then Green and looks noprmal. However when i start to print something it shows 'error' in the print queue and it never prints.
    i checked the front cover, toner engagement, paper jam ...
    Please tell me how to fix the problem. Is toner low, or ....?
  • Anonymous Nov 27, 2008
    red light on line error
  • pyrope93 Nov 29, 2008
    I have on line /error red light. Toner/save has no light a all. I hachecked all connections - everything if fine.
    LADA
  • raj07 May 11, 2010
    when i switch on the printer it goes inlilise but after some time on line led start blinking in red color
    kindly provide the solution
    Brigadier General:
  • 6,966 Answers
The online/red light would only come on if:
1. there is no paper;
2. missing communication (USB) with the PC;
3. the front door is only partially closed ;
4. if the toner/cartridge is not fully engaged and locked in place; and
5. internal printer error(s).
More often, it is either the door or the toner that causes this.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Posted on Feb 10, 2008
  • molly309 Oct 12, 2010
    Thank you! The front door was partially open!
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
The red light is on how to repair? (On line/ error)
the red light (online error) means that the printer is off line. How do you fix it? you press the "ok" or "reset" button and it puts it back on line and ready to print.
May 03, 2011 | Samsung ML 1610 Laser Printer
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Om line error red light is on
Try this solution: Check for paper jams when the "Error" LED lights red. Open and close the front cover. The paper may automatically be ejected from the printer. Gently pull any remaining jammed paper straight out. Open the front cover. Pull the toner cartridge out. Pull out any internal paper jams.
Nov 21, 2010 | Samsung ML-2510 Laser Printer
On line error
red line error problem
May 03, 2010 | Samsung ML 1610 Laser Printer
On Line / Error light red and printer can't work on ML 2010
Derek Kwaku Asamoah box mc 279 Takoradi. Please am using your product "samsung ml-2250 printer" and the problem is that the online/erro light is on. thank you for your co-operation and i hope to hear from you soon.
Jun 08, 2009 | Samsung ML 2010 Laser Printer
Samsung printer ml 1510 red light flashes after self test
Red Error Light Stays On The following conditions can cause the On Line LED to glow solid red:
  • Printer paper is jammed inside your printer.
  • A cover is not be closed properly.
  • The toner cartridge is not inserted properly and needs to be reinstalled.
  • The toner cartridge is running low.
  • There is no paper in the paper tray.
  • The paper inside the paper tray is not be installed correctly.
Red Error Light Blinks If your printer's On Line LED is blinking red, your printer's toner is exhausted and needs to be replaced. On Line and Error Light Blink Simultaneously
If your printer's On Line and Toner Save LEDs blink simultaneously, your printer requires service.
You can go to samsung online service request http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
Mar 21, 2009 | Samsung ML 1510 Laser Printer
On line/error and toner/save lights on
try to find some jam paper inside your printer or try to re-insert the toner cartridge....
Oct 26, 2008 | Samsung ML 2010 Laser Printer
Diagonal white lines...
Thats the first stages of the 3 red lights ,the white lines are vertical sheering caused by the vga chip.Microsoft now give 3 years warrenty for the 3 red light error plus if you have only just had it back from Microsoft then it will have deffo got a year on it anyway.
Jun 08, 2008 | Microsoft Xbox 360 Console
Samsung ML 2010 Laser Printer Logo
2,036 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
