Question about IBM ThinkPad 600X Notebook
Troubleshooting errors when i turn the computer on it loads up then goes to a blue screen that says to chack my viruses on my hard drive but i can't because the whole computer locks up, i can't even turn it off, i half to remove teh battery in order to do so. please help
  • Jack Russ Feb 10, 2008
    still went to blue screen
What do error code 39 means in my device manger on my dvd-rom on my thinkpad 600x
Posted on Dec 17, 2009
    Problem Solver:
  • 19 Answers
Try starting the computer in Safe Mode.
Then run the anti-virus.
Posted on Feb 10, 2008
My computer is unable to boot in any of the options, what do i do?
Booting problems with your laptop occur when the computer gets infected by a virus or when there are underlying hardware problems.You can use several troubleshooting techniques before taking the laptop to a service center for repair.
1. Turn on the laptop without pressing the power button too long, to prevent it from turning on and then turning off. Also make sure that the laptop has enough battery power to boot up.
2. Unplug any external drives connected to the computer. These include flash drives, external hard drives or any CD or DVD in the optical drive. Listen closely as you boot the computer. If the laptop is emitting ticking sounds and refuses to boot up at all, the hard drive or another internal component may be damaged. Consider bringing your laptop to a service center.
3. Turn on your computer and boot to "Safe Mode" or "Last known good configuration" if the computer powers on but displays an error before it boots the operating system. If this is the case, the laptop may be infected with a virus.
4. Use the "System Restore" feature in Windows to restore the operating system to an earlier time. Note, however, that this will not work for those whose computers have the "System Restore" feature disabled. Click "Start," "All Programs," "Accessories," "System Tools," and then "System Restore." When the dialog box appears, click on the box for "Restore my computer to an earlier time," and then "Next." Select the restore point that you want and follow further instructions.
5. Resolve a "blue screen" problem. This error screen appears before booting, and is caused by several factors such as virus infection or hardware failure. Read the error message to determine what factor caused the problem. The error message should include troubleshooting tips.
6. Consider repairing the operating system if the computer does not boot at all. This procedure will repair the operating system without erasing your data and settings. Access the Resource list for instructions on how to repair Windows.
I hope you find it very helpful. Thank you for using fixya.
Aug 15, 2011 | Computers & Internet
My dell 600 goes into the blue screen and it gives me an error. ***STOP: 0x0000000A (0x017F0304,0x00000002,0x00000000,0x8046061c) IRQL_NOT_LESS_OR_EQUAL ***Address 8046061c base at 80400000, DateStamp...
try to start in safe mode and if this is start normally , probably you have a virus, or a wrong driver installed. If you get the same error blue screen also in safe mode is possible to have an imperfect connection between hard disk and mother board, or a RAM failure Those are most common problems. If you don`t have important data to lose on system partition, try to reinstall the system operation (windows) If you get the same blue screen , ... definitely you have hardware problems like HDD or RAM malfunction.
Feb 28, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
My Seagate starts to boot up but then goes to a dark blue screen(no words) and you can hear the H.D> working, then the computer beeps once and nothing further happens.
the blue screen, is usually a Hardware Or Software ( operating System error ) The Computer beeping Once, States that The Computers Hardware is Fine. I,d try formatting the hard-drive, and reinstalling Your Operating System et,c. I,d assume this is a missing or corrupt windows system file. Or possible hard-drive error. ( virus-Trojan-Worm ) are also suspect.
Mike @ Compurepair.
Dec 01, 2009 | Dell Dimension 3000 PC Desktop
After formatting my pc is unable to run
(1)When you power up the computer press F8 key thne if you are able to see safe mode and other menu then enter in safe mode.Then go to start menu->run type in run "chkdsk /r"
thne press "y" then scan your computer with antivirus. uninstall that antivirus because sometimes it conflict to windows.
then restart computer thne wait untill it check disk and fix errors.
Then you can see desktop screen.
(2)But if you are not able to enter in safe mode then you need windows disk or recovery disk.
Then boot computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then go to boot option and set frist boot device as your cd or dvd drive.
Then save and exit settings.
Then insert disk in rom then it boot with that disk.
then follow the procedure and enter in recovery console .
Type in console prompt "chkdsk /r"
the press "y"
then it fix error on disk.
Then check in normal mode if still not load windows then follow above procedure again but this time select repair previous windows option so it repairs old windows and you get your old windows .
Let me know if you need further assistance.,
Thanks
Nov 06, 2009 | Computers & Internet
Unexpected "shutdowns"
I suggest you to clean the vents near the fan by opening your laptop. Also remove any recently added hardware. The issue can occur even due to bad RAM. I recommend you to try the steps in the below link:
http://notebook-solutions.blogspot.com/2009/06/troubleshooting-blue-screen-errors.html
Jun 26, 2009 | Computers & Internet
Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Apr 13, 2009 | Dell Inspiron 1501 Notebook
When I attempt to log on to my computer, I get message "Loading personal settings", but it immediately changes to "Logging off"...I can't even log on.....HELP!!! I am using an emachines w4685....
My Name is ArmyMason, I am here to help you. Are you seeing any flash of Blue Screen before it reboots? If not it sounds like you have a boot virus. If you can't boot to Safe Mode best the way to fix this is to pull out the hard drive and put it into another computer that has up to date Antivirus. On the hard drive are pins with a little plastic piece attached to them above that should be a diagram SL = Slave, MS = Master, CS = Cable Select. Depending on the Setting the persons harddrive that is in the computer you are about to put that Hard Drive into depends on the setting you need for your Hard Drive. So remember or right down the setting of your hard drive. If there hard drive is set to Master set your hard drive to slave. If there hard drive is set to Cable Select set yours to Calbe select. With the computer off and unplugged, locate the cable that the hard drive is connected to and take your hard drive and connect it to the second connector which is in the middle of the cable. This is where all slave hard drives go. Note: Dont worry you wont infect the host computer with a virus, because its not an active partition. <--- techy info... Now boot the computer and once the Hard Drive is detected run the Antivirus program on that drive.
There are other solutions, but this is one way you can remove the virus without having to format your computer and start over. If its a Blue Screen please make a post with blue screen issues so that we can figure out exactly what the error is.
Feb 24, 2009 | eMachines W4685 PC Desktop
Computer wont go past a blue error screen
Your hard drive may have quit(died). No good solution other than replace the hard drive. Do you have a restore disk for you computer, to use after replacign the HD?
Here is the website for Acer PC
Dec 19, 2008 | Acer Computers & Internet
IBM ThinkPad 600X Notebook Logo
95 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
