Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
John deere 425 lawn tractor. it wont start but it has spark and fuel the starter engages and the fly wheel turns
My John Deere did the same thing. Turned out to be the emergency brake sensor.
Posted on Jan 21, 2010
    President:
  • 1,627 Answers
If your tractor has an anti back fire solenoid in the front of the carburetor then it should start if you remove it and cap it off with a pipe plug.It should run if the solenoid is the problem,if so you really should replace it but if it is'nt prone to backfiring with it remove you don't have to.You may also have a bad seat switch,confirm this by jumping the plug with a piece of wire to temporarily test it.
Posted on Jan 14, 2010
SOURCE:
What causes starter housing to break near the fly wheel of John deere tractor 2950?
The starter armature may have been stuck while engaged with the flywheel or possibly just a casting that failed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/justin_3ae27a9d61d6acd4
Mar 03, 2015 | John Deere Garden
Have a 166 that just spins when starting...seems like it doesnt engage....starter or plugs?
Well seein how it turns over there could only be a lack of battery power on that note... spark plugs could be the problem but its most likely water in the bowl of the carb try to a very small drizzle in the carb and that will tell ya if its water insted of fuel in the carb... also depending on the age it could have point any more its electronic spark from the altinator under the fly wheel never suposed to fail.
Oct 03, 2012 | John Deere Garden
Our John Deere 160 lawn mower wont start. Installed new carb, fuel filter, battery. Has spark but wont turn over and run.
if the engine doesn't spin look at the starter if it has spark and a new carb is there power to the solenoid on the bottom of the carb does it fire on carb cleaner?
Apr 27, 2012 | John Deere Garden
My john deere L130 riding lawn tractor has spark and gas going to the carb but wont start. it has new spark plug and fuel filter When starting fluid is sprayed into carb it runs till its burnt up and...
I had a JD 111 rider that may have had the same problem. Turned out to be the fuel line had a weak area and would **** together and not allow the fuel through. It's a cheep place to start.
Good luck!!
Jul 11, 2011 | John Deere Garden
How do I change a spark plug in a John Deere SX75 lawn mower? I can't figure out how to get to it.
I haven't been able to get mine out, but I can get to it. There is a shield held on by two fly nuts. It is right behind the seat and on the opposite side of the mower than the lever that engages the blade.
After the shield is removed, there is a black wire running to the top of the spark plug you should be able to pull it off.
Then you'll need a spark plug socket and an extension. I think it may be a 13/16 size socket that you will need. Turn gently back and forth till you get it out.
Apr 17, 2011 | John Deere Gx75 Rx75 Srx75 Sx75 130 9hp...
My john deere 425 wont start cranks motor spins will run a few sec with starting fluid then dies
Check your fuel filter and see if it's clogged. You might be able to blow it out with an air hose if it is.
Feb 08, 2011 | John Deere 132 425 Lawn Tractorsnow...
John Deere 425 AWS no start, no nothing???
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
Oct 16, 2009 | Garden
BACKFIRES THROUGH CARB,WONT START ,MOTOR IS KAWASAKI FC420V IN A JOHN DEERE LAWN TRACTOR
Most likely water in the fuel. Drain the tank and clean the carb. replace with fresh gas. Mr fix it is a dumby
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
1,909 people viewed this question
Top John Deere Garden Experts
Dave
Joseph Mueller
Joseph Mueller
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
