On my screen it says connected, when i fully charge my mp3 also unplug the usb cord. to figure out how to turn it on. also the screen has four arrows going in the same direction .
    Master:
    Sergeant:
  • 462 Answers
Please specify your player name and model.
Thankyou
Posted on Feb 10, 2008
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
My daughter got a Polaroid mp3 player model PMP 180-4 for christmas and now does not want to turn on, what can be done to fix it?
I was able to reset my daughter MP3 while it was plugged in with the USB cord and then charged it fully and it works fine now. It appears I also had to adjust the on/off button.
Jan 23, 2012 | Audio Players & Recorders
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB...
When I switch the MP3 player on on the screen appear TELEFUNKEN and then it automatically switch off again. I checked the battery and it is fully loaded. When I connect the MP3 to the socket with the USB cord to charge the battery on the screen appears the following: IDLE and some kind of symbol. Can you please help?
Dec 16, 2010 | Truly MP310 MP3 Player
My fully charge sony media player NWZ-E435F will not turn on
Hey...Just remove the Battery for 2mins, reload and Power ON again...It may work
-sai
May 21, 2009 | Sony Walkman NWZ-B135 MP3 Player
Does not charge
Well, it sounds as though your battery is shot. However, before completely giving up i would restore the ipod in itunes and then let it fully charge. After it says "fully" charged, disconnect and test. if it still has no charge, reset it by holding down both the menu and center buttons until you see an apple appear on the screen. If after these steps it still does not charge i would check into getting a new battery either through iPodbatterydepot.com or by calling apple tech support at 1-800-APL-CARE (1-800-275-2273) Good luck
Apr 19, 2009 | Apple iPod nano
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
Unit will not turn on
Your battery is recharged when connected to your computer. Turn the player off and connect it to your computer via the USB cord. The computer must be turned on. Initial charge should be for 10 hours with subsequent charges 3 to 4 hours for a full charge. A quick charge of 1-1/2 hours will give you a 70 percent charge. A fully charged battery will last up to 15 hours under normal use.
Dec 09, 2008 | GPX MW3837 MP3 Player
Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
May 09, 2008 | Samsung Yepp YP-F1X MP3 Player
Craig mp3 player
u have to plug the usb cord into the computer with the computer on an then it has to be in the mp3 screen then it charges
Jan 02, 2008 | Audio Players & Recorders
Flashing red light on display
1st step - print a self test report Press and hold the OK button. Then press the left arrow key one time. Release the OK button. The test page prints OR Press the OK and Help keys simultaneously. The test page prints print the test pages 4 time minimum 2nd step - reset the printer If the printer is not off, press the Power button to turn it off. Unplug the power cord from the wall outlet. Unplug the power cord from the back of the printer. Unplug the universal serial bus (USB) cable from the back of the printer, if connected. Wait 30 seconds, then plug the power cord back into the printer. Plug the power cord back into the wall outlet. Press the Power button to turn the printer on. Ensure that the memory card has been removed from the memory card slot. Make sure plain paper is loaded in the In Tray. Hold down the OK button and press the Right arrow button four times. If the test page prints, re-connect the USB cable to the printer. OR IF YOU ARE NOT ABLE TO DO SO THEN start - printers & faxes - click on the printer icon highlighted with a correct symbol ( ensure the proper printer is highlighted )- right click on the icon - properties - print test page option at the bottom of the properties screen. 3rd step - if the USB is connected to a USB Hub then disconnect it from the HUB and connect it directly to the wall socket.Make sure the USB cord is of the proper measurement as mentioned for the printer in the User Manual. 4th step - visit www.hp.com left side of the screen you shall see an option SOFTWARE & DRIVERS DOWNLOAD click on that in the next screen a tab comes up mentioning FOR PRODUCT enter PHOTOSMART D 5160 and hit enter / click on the arrow beside it choose the OS under DRIVER YOU HAVE OPTIONS LIKE - » HP Basic Driver (recommended) » HP Full Software and Driver (before downloading it uninstall the s/w & then download it )-DO THIS ONLY IF THE 1ST OPTION DOES NOT MAKE THE PRINTER FUNCTION FINE STILL ERROR PERSISTS : - replace if under warranty/service the printer in the service centre
Sep 19, 2007 | HP Photosmart D5160 InkJet Printer
32 people viewed this question
 Grubhead
Grubhead
