Phillips Ch # 27f007583 tv turns on with lines 1 inch apart across the screen, the brighten then shut down
  • 5,138 Answers
You have a open resistor & maybe video ic on the CRT board this is the board connected on the picture tube. unplug this broad off of tube and see if set comes on and will stay on.this is a easy fix if you know how. cost to repair in shop should not be more then 75.00. ThankYou for using FixYa. Have a Nice Day.
Posted on Feb 10, 2008
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
Dec 20, 2015 | Televison & Video
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
Jvc rear projection tv
Do yourself a favor and dump this old TV, new ones are much better and cost is very low due to low demand.
May 18, 2012 | Televison & Video
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
May 02, 2017 | Panasonic TH-50PX500U 50 in. Plasma...
Grey lines
this a vertical circuit, and HV Circuit Defective, send to repair
Jan 15, 2010 | Philips Magnavox 27MS343S 27" TV
42 inch samsung lcd tv darker on one side
Its one of two things, bad lamps in the panel or bad Tcon board
Dec 24, 2017 | Televison & Video
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
13 inch rca true flat tv
if it is a straight thin line from left to right you have a vertical problem time to call service tech
Nov 29, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
