Philips 27RF70 S125
Older set, but little used. Began exhibiting problem a year ago.
Television kept dropping off intermittently. Upon advice of professional, replaced Small Signal Board. Set now runs reliably again, and all seems fine....but screen display shows right and left pincushioning. Professional advice say all such adjust are digital, and require service manual and probably EEPROM programming.
Any easier advice to try here, before I just start tinkering?
  • 84 Answers
Look for any burnt capacitors in the horizontal sweep circuit. They usually cause the pincushion.
C-Dog
Posted on Feb 10, 2008
VR550 : no signs of life at all after period of absence
Seems that way since repair not cost effective.
Sep 22, 2017 | Philips VR550 VHS VCR
Philips plasma television began intermittently blacking out after being left on 24 hours a day for approximately 3 years.(maybe exaggerating just a little) What can I do to fix the problem? In the short...
This is a common fault as the set on ageing deteriorates in the connections. There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Jul 14, 2011 | Philips 42FD9954 42 in. Plasma HDTV
Water flows continuosly for 1minute after switched off
You need to check all valves, one of them must be broken or too old.
Also the pressure is a little bit higher in there, but there is nothing to be afraid of.
CIAO
May 05, 2011 | Home
My RCA tv has been working fine for years. A few days ago it began to have intermittent popping sounds. Picture is clear and sound is good. I recently dusted the back of my set and I'm sure some dust must...
hi there,
if u know how to work with your set u can:
1. open the back cover case of your tv and try to find a foreign objects inside and clean it up with your vacuum cleaner.
2. popping sounds sometimes due to lossen parts, bad socket contacts, too much dust and dirts ,corrosions .and when cleaning you unplug first your TV set to avoid electric shock. i hope this will help a little. Thank You.
Feb 08, 2011 | RCA TruFlat 27F520T 27" TV
Philips Plasma 42" - constant purple haze
if the set is less then a year old it may be under factory warranty.
it sounds like the vscan, vset , or vsus voltages are off..it could also be the panel itself..contact philips
Nov 25, 2007 | Philips 42FD9954 42 in. Plasma HDTV
12 yr old JVC 36'' television
The little button on the main circuit board may be sticking intermittently causing your set to do this. This little push button was operated by the piece your 3-year old broke off.
Stargazer
Nov 16, 2007 | Philips Magnavox 20MT133S 20" TV
Astar LCD HDTV Monitor
mine also does the same thing on a 30' model and have found out it is a burned out power supply....unfortunately i have been unable to find repair parts because the company has been forced out of business...
Nov 08, 2007 | Astar LTV-3201 32 in. LCD Television
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
