Question about Car Audio & Video
Looking for eclipse 32440 premier amplifier
Its a gray or white amp i purchase at the pawn shop but i don't know how many watts it has. also it is a 4 channel. please tell me a little more about this amp. how old is it? also it is in comparison with the 32430 amp.
I got my eclipse amp at
Posted on Aug 25, 2008
Is this a good power amp what are todays sinfo on it
Posted on Apr 26, 2008
  • john000 Apr 26, 2008
    the out put power 2o:120w x 4 ch,4o:85w x 4 ch,4o bridged 240w x 2 ch
    its gray
How to choose a car amplifier
I have seen several (ok, MANY) posts here lately, asking about how to choose an amplifier, with all sorts of "Is this good...?" types of questions.
Here is what I look at when choosing an amplifier, and in their order of preference:
1. Power. I know, this is where MOST people look first, but it's the very reason you are buying an amp, right? Also knowing Ohm's Law, and knowing that I will almost always load an amplifier with the maximum specified impedance (impedance - 4 ohms or higher, NOT load - 4 ohms or lower), I need to know exactly how much power I am looking at to start with. When loading an amp with a higher impedance, the amp will make less power, so I have to keep this spec in mind the whole time. My speakers are almost always chosen before I decide to start looking for an amplifier, I know the impedance and efficiency numbers when I start. This will help me decide how much power I need or want for that particular driver compliment. I will NEVER look at "Max Ratings". They are often worthless, generally overinflated, selling tools, designed by old-school, low-end amplifier companies, originally made to sell product. (You remember how it went (and still goes today)... This 800 watt amplifier is only 200 dollars, but the Nakamichi 160 watt monoblock is 1300 bux for the pair. Which were (are) YOU going to buy?) Ahhhh, the power of advertising... Classic Nakamichi, Alpine, Linear Power, Orion, Eclipse, etc., THEY never posted "Maximum Power" numbers, did they? Unfortunately, even the good products of today will state maximum power output, I just disregard the numbers posted.
2. Signal to noise ratio. This one I place a bit more weight on, especially when the amplifier is going to be used in a mid-bass (important), mid-range (more important) or highs (MOST important) application. The higher the better, and there is no exception to this rule for me. Amps with tube stages are typically less capable than their solid state stablemates in this area, but I do make exceptions for tube amps. It is NOT a terribly important spec for a bass amp, so when shopping for a bass amp, don't bother with this number. Dedicated bass amps, BTW, usually offer awful SNR numbers.
3. Efficiency. Here's where you will be able to tell a decent manufacturer from the ****. Let's say you are looking at an 250 watt (RMS) amplifier. The first physical thing I look at, is how big a fuse do they recommend (or what size fuse is in the end of the amp)? I know right now that 250 watts OUT will demand (and I use 50% efficiency to keep it simple) 500 watts in. 500 watts in, divided by the (car running) battery voltage (14.4v) is about 35A. If I look at the end of the amp, and see a 20A fuse, I'm walking away, as there is no way that amp can make 250 REAL watts, continuously. 14.4v times 20A, equals 280 watts in. 250 watts out, divided by 280 watts in, translates to an 89% efficiency. In a class A/B amp, this is an impossible number, and it even stretches the imagination for digital amps, as well. The theoretical MAXIMUM efficiency for class A/B is 66%, (95% for digital) so someone is lying. I don't care WHO the manufacturer is, if these numbers don't add up, I will start looking elsewhere... Now, if all the other specification look good, AND I can get in the vicinity of the RMS power I am looking for, I will buy an amp that's efficiency number might be stretching the truth a bit. My old Nak 160 watt monoblocks had 40A (that's 480 watts in - a 33% efficiency, people!) fuses in each one, and they ran hotter than a firecracker, even loaded at over 8 ohms. I liked that. smiley1.gif
4. Terminals. A frequently overlooked part of an amp, this is a very important part of an amp to me. A car is a place frought with vibrations. A cheap or cheezy feeling connector in power or speaker terminals and most ESPECIALLY in the RCA inputs, will often cause problems in the future. Setscrews for power, quality terminal blocks for speaker outputs, and Tiffany style RCA connections (the type attached to the chassis, rather than a block of plastic soldered to the PC board.) The quality of the I/Os can be a direct indicator of the attention to detail paid to the rest of the piece. Translation? Overall Quality.
5. Heat sink. This one is simple. How does it look? I eventually chose Eclipse gear, because it looked like jewelry. Fine finish and appearance. Also, heatsink size and quality can be another indicator of quality of the amplifier as whole. A heavy heatsink will also provide better thermal stability, a nice thing in an amp.
6. Damping Factor. I used to place more emphasis on this spec, but my research recently (over the last few years, really) has, while not proven to me it is a useless spec, has not proven to me it is an extremely important spec. This is why this particular spec is a little further down the list. While I place a bit more emphasis on it for a bass or mid-bass amp, I, admittedly, place less weight here than I used to...
7. Price. Money rarely means much to me in an amp, (much like my computers - "Life's too short to build slow computers." - David Draper) it's something I am going to be keeping for a long time usually, so I will save if necessary to get EXACTLY (or close to) what I am looking for.
These are the things I look for when trying to decide on an amp. OBVIOUSLY, there are going to be VERY few amps on the market that will make me happy across the board, but then some of the physical characteristics listed above can be made to fit me and my desires with a little time, a couple extra bux, and some careful use of a soldering iron. All of the above things will cost more, but it will ADD more to the finished product as well...
on Mar 27, 2010 | Car Audio & Video
I have 2 sony xplod 4ohm subs rated 350w rms and 1200w max, i have them in really shallow boxes because i drive a single cab toyota, i know these subs **** but i do also know that they can hit alot harder...
the premier amp is better since it has a better rms rating (360w total or 160w each sub) than the eclipse (280w if you bridge all 4 channels which isn't possible but 140w for each speaker bridging 2 channels per speaker). Neither are going to push your subs but if you get another amp wiring kit and use one amp per sub they will sound a lot better and you could just hook both power wire and ground wires from the bridged channels to the power and ground terminals for the sub. That would be my suggestion since the subs are rated at 350w and each amp is 280w and 320w which will push but not blow the subs.
Aug 17, 2010 | Sony Car Audio & Video
Need radio wiring diagram for 2001 mitsubishi eclipse
CHeck HERE the 2001 diagram.
Hope helps (remember rated this).
Jul 05, 2010 | 2001 Mitsubishi Eclipse Spyder
Well i want to hook up hifonix amp and one pioneer premier un my hyundai xg350l and i want my stock radio to stay i know i need some sort of adapter to create rca's and also where would the remote line go...
you need a (loc) line out convertor you can get at best buy or radio shack and the remote wire will need to be tap in at the fuse panel to the radio fuse. so that amp comes on when the car is turned on.
Feb 02, 2010 | Stingpro ST444 1850 Watts Complete...
Audio is off in security mode
You should try downloading the Owner manual to see what the means exactly, you can download the entire manual at
Apr 06, 2009 | Eclipse AVN5500 Car DVD Player
I don't know how many watts is this amp
ECLIPSE makes a 32440
If this is the amplifier you are looking for specs on...
4 x 85W @ 4 ohms (13.8V - 0.1% THD)
4 x 120W @ 2 ohms (13.8V - 0.1% THD)
2 x 240W @ 4 ohms bridge (13.8V)
Thanks for using FixYa -a FixYa rating is appreciated for taking the time to answer your Question.
Mar 28, 2009 | MTX Thunder 1501D Car Audio Amplifier
What is the watts of this amplifier
The XM-1002HX is a two-channel amplifier with power ratings of 100 watts x 2 or 280 watts x 1 into 4 ohms and 140 watts x 2 into 2 ohms. ...
Mar 21, 2009 | Sony XM-1002HX Car Audio Amplifier
Sub+amp configuration
With a single 4-ohm subwoofer, usually the best choice is a 2-channel amp that can be bridged to a single channel. In your case, the sub is rated for 1000 watts. Not many amps are rated for that kind of continuous power into a 4-ohm load. Kicker doesn't list a minimum power rating, which isn't unusual in subwoofer specs. Depending on your budget, I'd look for an amp rated for 300-500 watts minimum; the higher, the better, up to 1000 watts. Most amps will have several power ratings, based on the load impedance and number of channels driven. A typical 2-channel amp might be rated like this: 150 watts x 2 channels at 4 ohms 300 watts x 2 channels at 2 ohms 500 watts x 1 channel at 4 ohms. The power rating you'll want to look at will be the 1-channel, 4-ohm rating. You can look at mono amps, too, but in the power ranges you're looking for, a 2-channel amp will probably give you the best value. However, if you can find a mono amp with a high enough 4-ohm power rating, it would run cooler and might last longer than a 2-channel amp with comparable power. When looking at mono amps, you'll find their highest power output will be at 2 ohms or 1 ohm; make sure you're checking the 4-ohm rating when making comparisons. Some amplifiers that might work well for you: Kicker SX900.2 Kicker ZX850.2 Alpine PDX-1.1000 Rockford T600-2 Hifonics ZXi 1006 Premier PRS-D2100T Power Acoustik OV2-2200
Jul 05, 2007 | Kicker C12-4 Car Subwoofer
Car Audio & Video Logo
434 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
