Tray error on a jvc axad8 5 disc dvd shelf unit
IT HAS ONLY BEEN 12 MTHS since purchased used 15 times only,
I was dusting unit and moved it out at the same time my finger must of hit the eject button while me hand was covering the front loader. I felt it try and open but the of course could not. It now comes up try error! when I try to open it any disc level>>''I have tried the usual on and off. Should I try and force?? one disc platform??
  • 56 Answers
Don't do anything by force you'll only make more damage.Its one disc platform and its mehanism is much more complicated than normal one.It has an "elevator system inside,the optic goes up and down to take a disc and every disc is laying on moving platform which deliver the the disc to the optic,and even some servicers are afraid to get deal with it.Was any disc in the unit when you moved it???If it was then it got out from laying plate,stucked in the mechanism and blocked the whole system.Or some of the laying plates has jumped of from its seat and blocked system.I repeat its very tricky,there are a lot of moving parts which has to be fited to the wright place,otherwise something can be broken.It can be home repair only if you are real specialist otherwise go to the service
Posted on Feb 19, 2008
My jvc 5 disc player wont play cd nor dvd.says tray errr. wont open to eject dics or play
It is possible that the loading belt needs to be replaced, or the timing gears are out of sink, either way it must be taken apart to find the problem, sometimes I find the gears ware out causing the unit to lock up. When you hit the eject button do you hear a motor running? that should be the sound of the loading mechanism trying to eject the tray.
Dec 23, 2010 | JVC FS-GD7 Shelf System
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
Tray keeps moving
Check inside the tray to make sure no obstacles are preventing the tray from opening fully.Also try a good cleaning disc; dust may be inside the unit.Check and make sure that the button on the front of the panel is not jammed or moved slightly, and is using a full range of movement. Push the putton, and see if it moves solidly. Lastly each manufacturer has Firmware upgrades for the controller chip that runs the tray.You can go to the website of the Manufacturer of the unit, and type in the Model number and make sure that your Firmware does not have an update.
Jan 19, 2010 | Televison & Video
My cd player says locked when i try ejecting the disc trays it is a jvc uxs77
on the one I have you hold down the stop button and the eject button at the same time to unlock but it is a diffrent model maybe it will work.
Oct 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
JVS UX S59, every time original disc inserted readsawhile and comes up saying no disc. please help, also adio not working. Everything was working fine, stereo has not been moved or dropped. Thanks Andy
the main problem with this is the laser .
the category 1 lasers are very sensitive .
the solution is to make sure your cd's are clean , not scratched and the final thing to do is clean the lenses of your JVC S59 make sure to keep this unit in a dust free enviroment .
Sep 26, 2009 | JVC UX-S57 CD Shelf System
JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
DVD TRAY WILL NOT EJECT
it is definately jammed and will need to be taken apart and unjammed safely to avoid dammage to the unit
Oct 11, 2008 | JVC UX-S57 CD Shelf System
CD player ate a CD!!
I fixed the same issue by forcibly pulling individual trays to their open position.  I removed the casing to gain better access (tons of screws) but you can probably gain clear access to the shelfs without removing the casing if you have good needlenose plyers.  I found a stuck CD within one of shelfs, wedged WITHIN the moving components of the shelf.  It works perfectly now.
Aug 01, 2008 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
LOADING
It is pretty common problem.
If all of your DVDs are having same problems,
it is most likely either optical sensor is at fault. The other could be the actual loading mechanism problem.
If the dvd tray(drawer) closes all the way in but the DVD disc never completes the loading(reading) procedures, 1) it could be simply dirty or damaged disc. 2) the optical pickup device (eye) is dirty or just went defective. 3) sometimes the drawer tray that houses the DVD did not complete to engage in disc reading position can produce this result.
I would suggest: first check the position of the drawer and condition(s) of your DVD disc itself.
If the pickup device(optical eye) is dirty or defective, that needs to be serviced by a qualified technician. or contact JVC service center. Their information can be found at
http://support.jvc.com/consumer/support/support.jsp?pageID=10
Feb 13, 2008 | JVC DR-MV1SU DVD Recorder/VCR
Disc won't play
Silmilar problem on a MX-D501T
At times the unit fails to recognise the music CD in the tray, or recognises its presence and shows tracks & time play on screen but doesn't initiate playing. The fault is erratic. Pushing 'play' on the remote doesn't initiate either.
Is this a faulty head or 'dry joints' somwhere?
Dec 09, 2007 | JVC MX-D301T Shelf System
237 people viewed this question
 Grubhead
Grubhead
