Question about Bernina Activa 130
Bernina Activa 130/131
My dog chewed thru the cord on my foot control. I attempted to repair which worked for a while, but now when I plug it into the sewing machine, the machine races full speed and I'm not able to control it with the foot control. On-line searches show a replacement (part #LV-1) is $130. Does anybody know of a site where I can purchase a new foot control at a more reasonable price?
  • 2 more comments
  • littlegem Feb 18, 2008
    Same problem except it's an Elna Super, no dog, new electronic foot pedal and won't turn off even with the one off switch. Unplugging is the only way to stop it???
  • gmickleyrn May 12, 2008
    I've simply lost my power cord in moving, where can I get a new one???
  • toscabelle Mar 09, 2009
    My dog did not chew thru mine, my father got the cord caught in the roller on a desk chair and went Rambo on it. The wire pulled completely out of the jack. Can this be fixed with out replacing the whole thing?
  • Anonymous Mar 15, 2014
    i think i need a new foot control. It is just dead at first i could pick it up in my hand and it would work but not when I put it on the floor. It does not work at all.
  • Bernina Master
  • 1,388 Answers
Because you say all was working for a while before this latest event, it will be the supressor that has failed, they are generally in the foot control (some machines have them in the main body near the power inlet) and it needs to be removed, it only stops interference to Radio & TV and is not necessary for correct function...............your nose will tell you if it is in foot pedal or inside the machine..
Unplug from mains, undo cover/s and find the electronic looking item which is cracked, burnt & probably oozing brown goo and smelling like burned plastic only worse.... Simply remove this from the circuit, clean the region with some denatured spirit, methanol or similar, wait until completely dry and re-assemble....this should fix the problem of the machine "running on" by itself....as to whether you have done a good job of the initial electrical repair, only you will know that.
By the way, how's the dog ? Guess the machine was not plugged in at the time !!
Posted on Feb 10, 2008
I have an activa 130 and the foot won't go all the way down
Is your machine fitted with a knee-lifter ? If so, its possible the knee-lift mechanism has got stuck, which will prevent the foot from coming all the way down. It's also possible that the foot lifter bar has slipped which will require re-setting. When the foot is lifted and the feed-dogs are dropped, there should be a clearance of about 7.5mm between the underside of the foot and the stitch plate.
Mar 02, 2012 | Bernina Activa 130
Bernina 930 foot control cord
Not easily - the plug is molded-on so it's best to get a complete new cord - they're still available.
Feb 02, 2012 | Bernina Sewing Machines
How do you oil a Bernina Activa 130? The manual doesn't say anything about it.
Remove needle, needleplate, presser foot and bobbin case. Now take a lint brush and clean under the feed dogs and hook area. take the bernina oiler(must be bernina oil only) now place a drop just below where the bobbin case clip on and one small drop under the feed dog area. replace items, sew out a test sample and away you go.
Apr 27, 2010 | Bernina Activa 130
Won't sew with foot dog down and using the freehand embroidery foot
Won't sew can mean more than one thing - the machine has no power or is seized up; the needle is not going up and down; the needle and bobbin are not forming a stitch.
When the feed dogs are down, you move the fabric by hand.
The presser foot has to be down to stitch.
If you wound a bobbin before you starting the sewing, did you disengage the bobbin winding feature(s)?
Mar 20, 2010 | Bernina Activa 140
Is there a way to lower the feed dogs ''a little''?
I thought this was free . . . didn't know I'd be asking to join. So, I called the shop where I purchased the machine. They were able to help me fix the problem.
Nov 12, 2009 | Bernina Artista 180
Bernina Activa 131: Feed Dogs won't come back up
Raise feeddogs with switch, then turn handwheel one full revolution to re-engage the gear......unless something is jammed, that should do it. Do you have your manual ?
Nov 30, 2008 | Janome Memory Craft 9000 Computerized...
Bernina Activa 135
Is it plugged RIGHT into the machine? Is there something caught underneath the foot pedal? might be time for a check up at your local sewing machine mechanic.
Oct 24, 2008 | Bernina Activa 130
Bernina Activa 135 foot pedal problem
If you can get acess to or borrow another foot pedal to try I would do this first any of the Activa, Artista range fit to try. The fault may not be in the foot pedal but in the main CB of the machine. This can give a fualt of lights on but no motor drive. In this case the board would need replacing by a technician. Hope this may help.
Jun 11, 2008 | Bernina 1008
Sewing Machines Logo
421 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
