Try cleaning the print head cradle with alcohol. That is what the little copper circuits on your ink cartridges sit in. Make sure you have it off before doing this. Clean it with alcohol and a swab if you have nothing else. Using something like a silk cloth would be preferable. The silk cloth will not leave fibers behind. Remove and reinstall your software if this does not work. And I do have to agree with the fella above. Sometimes HP printers just don't cut it. I had several. I also had a very nice Canon photo printer. The best luck I've had with all of them was a $15 Lexmark printer from Walmart believe it or not.
This is a classic failure mode of HP Printers. I've tossed out two of them for the same reason, after fooling around for hours and wasting a couple of cartridges. My solution? Buy a different printer next time -- Canon, Brother, etc.
SOURCE: HP 1220c problem
no manual. i replaced both cartridges. i didnt read instructions for installing cartridges. failed to remove tape.tape on both cartridges are removed.i can now print again.
SOURCE: How do I replace the black ink cartridge for hp 5610
make sure the printer is switched on
you can find a door at the right side end of the printer just open it and you can change the catirage
if you still cant follow use this below link
http://www.shopping.hp.com/webapp/shopping/store_access.do?template_type=product_detail&product_code=Q7311A%23ABA&jumpid=oc_R1002_USENC-001_HP%20Officejet%205610%20All-in-One&lang=en&cc=us
SOURCE: Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
