Question about Brother DCP-110C All-In-One InkJet Printer
My documents are printing on one corner of paper instead of in the center
  • 390 Answers
Hello,Check paper feeder for jams, and inside unit. Also run an allignment check and post back if no go for further help. cheers lilacgerry xxx
Posted on Feb 10, 2008
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
My HP 6280 will not print the full picture after it has been scanned. I put it in the right hand corner, chose the correct paper size and it still won't print correctly. Can you please help
Check corner marking for placing the document, place the document & scan through system, verify whether you got full scanned image? if not adjust the placement in correct position, once its OK, go for print there select correct image size(could be 100%) & paper size..I hope it will solve the issue..Best of luck
Sep 25, 2011 | HP Photosmart C6280 Printer
I am printing on 8 1/2 by 14 paper landscape. The document is not covering the entire paper.
Do you want the document to fill the page from corner to corner? You won't be able to do that due to the margin settings. The printer needs to be able to pull the page through the machine without touching the ink, so it can't print on every available inch of the page. You can minimize the margins as much as your printer will allow under the Page Settings menu, but it will always shrink the document to fit within the margins on the page.
Hope this helps!
Aug 25, 2011 | Epson Stylus 1400 InkJet Photo Printer
How do you set it to print in LTR instead of
Inside the paper cassete there is a dial were you can set your papersize.It is a blue manual switch switch it to LTR instead of LTR -R.There is also a document stop that you can remove to set it to the correct paper size.If you print from your document select portrait insted of lanscape.
Thanks for your support.
Dec 28, 2009 | Canon imageRUNNER 2270 Copier
Documents only print in the top left hand corner of the paper, and is too small to read. Paper size, is set correctly, document type is correct, the driver is the newest availalbe.... how do I fix this?
There is two paper size settings one in the document and one on the driver, check page size in word or pdf or whatever you are trying to print from, does it do it to all documents including windows test page or just some?
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Left corner of paper wrinkles when printing
I know several reasons, and they are all related to an obstruction of some sort..whether it be a small piece of paper along the paper path, to something slightly bent, or broken...impossible to say for sure
Feb 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
Printing documents with wide margins on letter paper
Did you try to reduce the document down so it would fit a standered size paper???
Sep 29, 2008 | Sharp AL-1642CS Copier
HP IIIp prints extra blank pages
HI there make sure that the paper tray guides are fully against the paper also try sending the job through the manual feed to see if you get the same problem. If you do not then it maybe that the paper cassette separation pad is worn and will need replacing. If your model has no rubber pad at the front of the cassette then you will have a metal hold over one corner of the paper make sure that when the paper lifts that the paper sits under the silver (Dog Ear) as this acts as a separator.
Hope this helps
Thanks J
Jan 28, 2008 | HP LaserJet IIIp Printer
Word 2007 Booklet Graphics print on wrong page.
did you try to preview your work and see if its coming out on the page like you want before you print try that and see if it looks right before you do your work, I don't know if that will help you out but I hope so.
Dec 31, 2007 | HP Media Center m7060n PC Desktop
Brother DCP-110C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
