Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon MP600 Mac Leopard Duplexing?
How can I get the MP600 to print duplex from my IMAC Leopard? O can't find how in any menus or instruction book. Thanks
  • 3 more comments
  • Anonymous Mar 05, 2008
    I can't get my MP600 to scan using Macbook pro with leopard :0(
    It prints fine.
  • Anonymous Jun 20, 2008
    same issue. limited functionality and menu options.
  • szepzene Sep 29, 2008
    Can not print double sided copies - had no problem with earlier Mac OS X-
  • Anonymous May 02, 2009
    Duplexing option greyed out in print dialog. Running 10.5.6 on MacBook Pro.
  • penni128 May 14, 2009
    Print ok...will not scan since I updated to Leopard.
    Genius:
  • 3,587 Answers
    Sniper:
  • 109 Answers
Why does paper jam when duplexing (printing double-sided)?
That question would require a book to answer. The simple answer is try turning the paper over. Why?? Check this link: http://dorothyoger.wordpress.com/2011/09/10/put-paper-in-the-copier-right-side-up/
Aug 08, 2014 | Canon Copier Toner, for Imagerunner...
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
Hi, Hope you can help, A CP 6015 jams on dupex 2nd side on entrance to fuser,it looks like something to do with pressure roller release mechanisum as when released an actuator moves across fuser entrance,...
The document I was thinking of referred to fuser wrap jams. I did some quick checking of duplex jams though and this might give you some guidance to check for.
These errors refer to jams when repicking to print side 2.
Cause Solution The spring of the duplexing media-repickup-sensor lever is unhooked Check the spring and place it in the correct position. The duplexing media-repickup-sensor lever is damaged Replace the duplexing feed unit. Poor contact of the duplexing media-repickup-sensor connector Reconnect the connectors of the duplexing media-repickup sensor (J1945), intermediate (J1909, J1950) and the DC controller PCA (J4105). The duplexing media-repickup sensor is defective Check the duplexing media-repickup sensor by the sensor monitor mode. If the sensor is defective, replace the duplexing feed unit. Poor contact of the duplexing repickup-motor connector Reconnect the connectors of the duplexing repickup motor (J1771), intermediate (J1908, J1939, J1941) and the duplexing driver PCA (J4104). The duplexing repickup motor is defective Replace the duplexing feed unit.
Mar 10, 2011 | Office Equipment & Supplies
How do I duplex print on Lexmark x6170
Good day! Try to follow these steps on how to do duplex printing using the Print Properties settings. With a document open, click File, Print. In the Print dialog, click Properties (or Preferences, or Options, or Setup) button. The Print Properties screen appears. You'll see three main menus: Quality/Copies, Paper Setup and Print Layout. In Print Layout, select Duplexing to print on both sides of the paper. Hope this helps.
Mar 17, 2010 | Lexmark X6170 All-In-One InkJet Printer
Canon IR1018 forces duplexing
Go to service mode MENU and #, clear all and ok,
after that machine goes to factory sett., reenter your sett. it should work
Jul 08, 2009 | Canon Duplex Automatic Document Feeder
MP600 printer won't use the 8 BK black ink
Quick and easy way to do this is to use the automatic duplex more as this uses the 8K cartridge instead of the 5K.
Thing to note is that the 8K is the photo black and dyebase whilst the PG5 is a pigment ink.
As a general rule you'll want to use the PG5 because it's cleaner and sharper for text while the 8K is much better for photo quality inks...
... and the reason it's used for duplexing? Simple... it dries quicker! .. So, you don't have to wait as long for the page to be pulled back in and you get less chance of smudging...
Hope that helps...
Mar 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Duplexing
Someone has changed the settings on the unit. If you go into Additional Functions press set on Common Settings scroll to Paper feed switch and set it for Speed Priority not Print Side for each category. The only other thing that would cause this is that each individual setting was set for 2-sided in which case you would want to check Additional Functions and each one Copy Settings, Printer Settings and Fax settings.
Nov 24, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Switching between color and black and white
Go here. In the search box in the center of the screen, type "print with black ink only" and click Search. Choose the appropriate link, and you will get instructions for printing from either Windows or Mac.
Jul 03, 2008 | Canon MX300 Office All-In-One Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
841 people viewed this question
old marine
old marine
