Everytime i turn it on it loads fine, but once it says building playlist, it stops half way and comes up with a message saying Build Error!! and then it turns off..
The problem is that you have a file, maybe in the half of your playlist, which is bugged or corrupted. Try to delete every single files and put them one by one to find out which file is bugged.
Visit the Australian part of the Samsung website (http://www.samsung.com) and go to the download centre. Select the option to download the firmware for the Samsung YP-U2. It will be version V2.211. The download will be a zipped folder. Unzip the folder on your PC and run the setup program. This will install the Samsung YP-U2 software on your PC. Connect the player directly to a USB port on your PC and start the YP-U2 program. Use a paper clip to press the reset button on the YP-U2 whilst at the same time pressing the PLAY button. Hold the reset and play button like this for ten seconds. Once your PC picks up the player it should automatically download the drivers. Release the reset button and follow the instructions on your PC screen to install the firmware. The process will delete all the files currently on your MP3 player but at least you will be able to get it working again. If you fail to get the download at the Samsung website, send an email to [email protected] and I will send you the zipped folder (almost 5MB).
Remove Mp3 player if you already connected to the USB port
Run the program (You should see something like: Please connect the device)
Hold down the Play button and connect the Mp3 Player to USB port(Hold down the play button while you connect the device, you should seea message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
After you hear the Windows chime "new device found" or the message"Initializing" on YP-U2J Updater, you can now remove your hand fromplay button.
Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
Click the "yes" button
Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
IMPORTANT: After updating the firmware, you MUSTdisconnect the Mp3 player and turn it on. You will see a 20% messagefor about 50 seconds and it will be restarted automatically.
Update: Pleasekeep in mind that if you sync your Mp3 player with a computer that hasa Windows Media Player 9 or 10, you should do these steps again
I plug in my mp3 player and it will say: charging. then it jumps to:
DON'T DISCONNET. and it shuts off and repeats. HELP ME PLEASE!!!! My email ID : [email protected] and [email protected] Thanks Vasu B N
Да такая же хуйня с Самсунгом!
