Question about Logitech Z-5500 Computer Speakers
Logitech Z 5500
How do I change the subwoofer for a better 10 inch. I tried taking the grille off but it's not coming. Yes, I removes all the screws.
I blew my sub last weekend. I did everything to get the grill off and finally had to drill holes in it to get to the others holding the sub down. It is screwed down over the plastic piece which holds the grill. I put a RF Punch in and so far so good.
Posted on Jan 07, 2009
You will probably get sound that is worse, because the box where the sub is in, is exactly calculated for the logitech sub, and if you put another sub in, it won't be.
so i suggest you leave the sub alone :D
Posted on Mar 21, 2008
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Dennis
First things first:
1) you can buy on audio stores, boxes for 10 inch speakers
then you can do this kind of work,
I try to do what you did, and you know what happend! *&^%$
Open Sky
Posted on Feb 15, 2008
I have the speakers S125i of logitech, but there is a piece that is loose inside of the speakers, at the begining the speakers sounds well, but then the left speaker stoped working. I think I'm able...
The Logitech is a little tricky. You need to carefully pry off the white bezel around the speakers and then pry away the grills. Under the grill you will find four screws holding the two speakers, and four screws set deep in holes.
Undo these eight screws and the front will come off.
Jul 20, 2011 | Logitech S125i
Looking for a subwoofer for logitechZ-5500
Hi, As Logitech does not sell this spare part, I suggest you to check on website such as ebay. Thanks and have a nice day !
J -
Mar 04, 2010 | Logitech Z-5500 Computer Speakers
Logitech Z-5500, no sound out of speakers
Hi there bud , There could be a number of problems as it is a refurbished Speaker Set ,It could be The Subwoofer yes , Have you tried it on other PC's? if it does the same then it is The SPeakers that are faulty :(
Hope this helps
Happy new year :)
Jan 06, 2010 | Logitech Z-5500 Computer Speakers
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
When I change the fuse in the z-5500 it
at this point your hands are tied to fix these due to a capacitor failure or whatever. you can try wrapping the fuse in aluminum foil but this may cause even further problems but i have seen it work before. be sure to keep a close eye on these if this works because the fuse is ultimately a safety device.
Jul 11, 2009 | Logitech Z-5500 Computer Speakers
Headlight replacement
you can access the outer headlights from under the hood. the inner healights have to be replaced by removing the grille. after grille is removed you will see 10 mm head bolts above & possibly below the headlight bracket remove them & headlight capsule should come right out.
Jul 08, 2009 | 1997 Chevrolet K1500
How to disassemble Logitech Z-340 sub-woofer
The speaker bezel can be removed in only two ways:
1) Somehow remove the grille in order to get a the screws which hold the bezel onto the cabinet. I tried to do this and couldn't get it to budge. Once I got the thing open I observed that Logitech used a LOT of glue to hold this thing together.
2) Drill holes THROUGH the grill above each of the 8 screws large enough so you can loosen the screws.
Once you get it open, you'll be shocked to discover what you thought was the subwoofer cone is actually A ROUND PIECE OF CARDBOARD fastened to the foam. The 4" driver is behind this fastened to a board halfway back pointing into the chamber containing the electronics.
You can get to the power transformer, but good luck removing it. The screws are nearly impossible to unfasten; more glue but more importantly incredibly awful access to the nut and screw (yes, a screw, not a bolt).
I wouldn't pay 5 bucks for this system. Luckily, I didn't.
Oct 27, 2008 | Logitech Z-340 Computer Speakers
No power in Z-5500 logitech speakers
The logitech z 5500 digital is very sensitive to power peaks. One of the most know problems is that the fuse breaks because of these peaks. I´ll show you how to replace the system´s fuse.
First of all, you just need to write down the specification of the system´s fuse. The system´s fuse specifications are printed in the back side of your subwoofer, right next to the subwoofer´s on/off switch. In an european system it says: "T2AH250V (Time Delayed)". If you use another power voltage (120v), it may say something different. Anyway, write it down on a piece of paper and go to an electricity store and ask for a similar fuse (It is very cheap. Not more than 1$)
-The best way to get a similar fuse would be by bringing the broken fuse with yourself to the store-
In the back of your subwoofer, using an screw-driver, un-screw the fuse´s cover and remove the broken fuse. Replace it with the new fuse, attatch it to the cover and screw it back again.
If you turn on your system now, it will probably work fine.
Oct 20, 2008 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Speaker stand problem
The stand was held on with a nut on the inside. There is not longer a nut on the inside of the hole, so there is now nothing for the stand screw to attach to. The nut is now stuck to the magnet on the speaker. You will need to disassemble the speaker housing to remove the nut from the speaker magnet and reattach then stand. peace. Paul.
Dec 31, 2006 | Logitech Z-5500 Computer Speakers
Logitech Z-5500 Computer Speakers Logo
293 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
