Question about Toshiba Cinevision DVR2000
Cinevision DVD player prob - asking for parental control
Hello, I don't remember setting up a parental control item on my DVD player. How do I reset that?
  • Anonymous Mar 07, 2008
    Cannot play DVD. Cannot disable parental control limit. Instruction to allow playing cannot be done with the remote provided.
5 Suggested Answers
SOURCE: How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Posted on Feb 22, 2008
SOURCE: parental code
with no disc in the player go to set up and go to change password i think the default is 99999 then you can change it to something you remember or keep it the same if you so choose. i would give that a try
Posted on Mar 01, 2008
JeremyM49
  • 127 Answers
SOURCE: item#dvp-fx820 parental password
the sony default password is 0000
if this doesnt work, the password must have changed,
good luck
Posted on Jul 03, 2008
  • 11800 Answers
SOURCE: Need codes for toshiba remote to work cinevision
There aren't any, your brand isn't supported on your Toshiba remote. The only thing you can do is to try all the other codes, maybe you're lucky and one of them will.
Posted on Jul 11, 2010
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
Jul 07, 2013 | Televison & Video
I set a parental control password on my alba lcd32880hdf 2 years ago and can't remember what it is. Can I reset it?
When you said this: They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!, is that dvd on the tv or a normal dvd player
Jan 01, 2012 | Alba XJR 1300 SP Televison & Video
Zenith DVD player DVB412 is requiring an entry for a Parental Control Limit on a brand new Across the Universe DVD. I've tried 0000, 3308 to reset the code, the reset button. It looks like others had...
Hello Hummer,
Please follow the instuctions below to reset the password and switch off the parental control on the Zenith DBV412.
1. Switch on the TV and DVD player
2. Switch the TV to the input for the DVD player
3. Remove any disc from the player
4. Press the SETUP key on the Zenith remote to open the on-screen menu
5. Press 2 1 0 4 9 9 using the numerical keys on the Zenith remote.
6. Press SETUP again to close the menu
This will clear any password that has been set. Now you need to switch off the parental control:
8. Press the SETUP key to open the on-screen menu again
9. Use the down arrow to highlight the PADLOCK for the parental control settings
10. Press the RIGHT arrow once to enter the parental control menu
11. Highlight RATING and press the RIGHT arrow once.
You will be asked to set a password. Enter something simple and easy to remember, e.g. 0000 then press ENTER. You will need to confirm the password by entering the same number again, then press enter again.
12. Use the UP/DOWN arrows to highlight UNLOCK then press ENTER
13. Press SETUP again to close the menu
You should now be able to insert your Across the Universe disc and play it. If you are still unable to watch the disc or you are unable to switch off the parental control feature, please let me know.
Regards,
BElectric
Apr 09, 2011 | Zenith DVB412 DVD Player
I cant watch any dvds on my dvd player as their is a parental lock on there, i have tried unlocking it but i need a code which i dont have, the model is a sony RMT-D175P
OK - to switch off the parental control on the Sony DVP-NS15 and reset the password, please do the following:
1. Switch on the TV and the DVD player
2. Set the TV to the correct input for the DVD player so you can see the on-screen menu
3. Remove any disc from the player and close the disc drawer
4. Press the DISPLAY key on the Sony remote control to open the on-screen menu
5. Use the DOWN arrow to highlight the disc and padlock (parental control) then press ENTER
6. Use the DOWN arrow to highlight ON> then press ENTER
You will be asked to enter a password. Press 1 9 9 7 0 3 then press ENTER. Don't worry that it's only asking for four numbers, you need to enter all six. After you enter the master password, you will be asked to set a new password. Set this to something easy to remember, e.g. 0000 then press ENTER and confirm the password.
Finally, if you don't want to use the parental control feature you need to switch it off. If asked for the password again, enter the new password you set.
7. Use the arrow keys to highlight OFF> and press ENTER
8. Press the UP arrow to highlight PLAYER> and press ENTER
9. Highlight LEVEL and use the arrow keys to set this to OFF
10. Press the DISPLAY key again to close the menu
If you have any difficulty unlocking the player, please let me know.
Apr 05, 2011 | Televison & Video
Cannot remember my parental control number is there an overide
try this:
Here is the procedure to reset the parental lock code:
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Apr 12, 2010 | Sony PlayStation 2 (PS2) Console
Parental lock on cannot open it
Actually its, 'select' then '7444', and all that does is reset the password.
Press the SELECT button and enter the 4-digit number "7444" whenever the Parental Control display asks you for your password. The old password is deleted.
You will then be prompted to enter a new password, enter whatever number you want, something like 0000, or a number that is easy to remember. If you wish to turn it off, just set it to off and forget about passwords.
Notes
- When you play DVDs which do not have the Parental Control function, playback cannot be limited on this player.
- If you do not set a password, you cannot change the settings for playback limitation.
- Depending on the DVD, you may be asked to change the parental control level while playing the disc. In this case, enter your password, the change the level. When you stop playing the DVD, the playback limitation level returns to the original setting.
After changing DVD settings:
To save your changes, be sure to eject the DVD before pressing the RESET button or turning off the unit with the MAIN POWER switch. Please note that changes will not be saved if you reset or turn off the console without first ejecting the DVD.
Sony Playstation 2 manual, pg. 19
Aug 06, 2009 | Sony PlayStation 2 (PS2) Console
My nephew put a code for movies, he forgot the code
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
http://www.techlore.com/article/10505/Resetting-Parental-Lock-Code-on-Playstation-2/
Jan 04, 2009 | Sony PlayStation 2 (PS2) Console
Code
1389 is the factory default
maks alot it on back of unit
Mar 09, 2008 | Cyberhome CH-DVD 300 DVD Player
Aug 24, 2007 | Zenith DVB412 DVD Player
Toshiba Cinevision DVR2000 Logo
205 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
