Question about Canon PIXMA MP830 All-In-One InkJet Printer
DVd label when inserting to print on to dvd the machine only takes in part of they way so does not print the whole label. Help
  • 2 more comments
  • twins2twins2 Feb 12, 2008
    Hi sorry and thanks for your replies, but it was me not opening the front cover onlly when it told me to I was opening before printing and having the tray with the disc ready in it. Stupid me.
    Now I am having a problem with when I go to print out and require the paper to be printed from the cassette it tells me to load paper and I have paper in the tray so it is not printing from the cassette can anyone help?? am I not doing something right. Cheers
  • brian c
    brian c May 11, 2010
    Sorry, i accidentally posted that on a different question...
  • brian c
    Is it printing on the label itself, or is printing it as though it's printing on a normal sheet or paper (top to bottom)?
All document printers with disc printing capabilities suffer from disc feed problems. It is an inherent design flaw that results from the machines original design to print documents. Loading discs to be printed must first "go around" the printer's paper feeding mechanism to accept discs. I got tired of using document printers to print labels on discs. I switched to a DiscPainter made by Dymo. It is a dedicated disc printer that was designed as such from the outset and not as an afterthought. It prints every bit as well as any document/disc printer but without the frustrating mis feeds. Although the Canon printer is great for documents its design limitations for disc printing are not easily overcome.
Posted on Feb 10, 2008
Xp-800 cd/dvd printing
The tray is for the DVD or CD itself, not for a label. The printer prints directly on the CD or DVD, you must use ink jet compatible blank disks, the white ones with no printing. You don't need a tray to print the label.
Oct 14, 2014 | Epson Expression Premium XP-800...
How do I make a CD label?
There is a user manual on the install disc, pdf-format. To get to the manual, insert the install disc and wait for the small window to appear. At the bottom are some options, one being "View User's Guide". Click that. Or you could access the pdf-file itself manually and copy it to your hard drive: After inserting the install disc, go to "My Computer", right-click on your writer drive, choose "Explore", double-click on the folder named "SE1", and look for a file called "SE1 Guide.pdf". Open it, or copy it and paste somewhere on your computer for future reference. Read Chapter 4 of the user guide - it is titled "CD&DVD LabelMaker". Here follows the chapter, illustrations excluded:
Chapter 4
Introduction
CD&DVD LabelMaker makes designing and printing disc labels
and CD/DVD inserts fast, simple, and fun. Customize labels with
your own photos, text, video stills, and music playlists. Hundreds of
professionally-designed themes are included inside. Supports
label paper templates by Avery®, Memorex®, Neato®, CD
Stomper®, and Direct to CD/DVD Printing with supported printers.
Getting Started
When you first start the program, you're prompted to select the type of
project you want to design and print: Disc Label, Jewel Case Insert,
and DVD Case Insert.
Once you've selected the type of project, you'll be prompted to select
the paper to which you'll be printing. Select your template from the list,
and then click OK. (You can also change your project type by selecting
a new one from the top pull-down.)
Designing your label
You can customize various sections of your label/insert depending
on the selected paper type/template. The main workspace in the
Design Label tab starts by focusing on one section of the label/
insert. For example, if you're using paper that has two disc labels, the
focus will be zoomed onto one of those labels.
Adjusting your view
Notice the two up/down arrows on the left side of the screen. When
applicable, you can click either arrow to shift the focus to the top/
bottom of the page. Click the Paper View button in the lower left
corner to see a small thumbnail of the page. Click the section that
you'd like to edit, and it will appear in the main workspace.
Changing the Background
The right side of the screen lets you change the paper background,
either by applying a color (Use Color) or graphic design (Use
Theme).
To change the background color, select Use Color. A color palette will
appear. Click the color you want. The color will then appear on the
label/insert in the main workspace. The palette is fairly robust. If you
select a new color that doesn't appear on the grid, you can add it to
your My Favorite Colors.
To delete a custom color, select the color, then click the - icon.
To add a design, select Use Theme. A pull-down at the top lets you
select from a variety of categories. Each category offers a variety of
designs. To select a design to apply to your project, simply click it.
Click the button to the right of the pull-down to search for additional
designs online.
Printing your project
A print preview displays your project.
If there are certain sections/components that you'd prefer to exclude
when printing, simply click that object (it will appear dulled in color).
If you change your mind and decide to print the object, simply click the
object again and it will become active for printing.
Print with Mask: This option is only applicable when printing disc
labels. If you notice that your prints aren't aligning properly with your
labels, uncheck this box. Instead of printing over the circular area of the
label only, a square version of each photo will print to cover more area
and fill the disc label.
Select Your Printer: From the Printer pull-down, choose your
printer.
Modify Your Printer Settings: Click the Printer Setup button to
view/modify your printer settings.
Set the Number of Copies: Use the arrow buttons to increase/
decrease the number of copies you'd like to print, or key in the value in
the available box.
(To be continued - ran out of space) From: 11407336
Dec 01, 2010 | Individual SlideShow Expressions
Microboards DX1 input problems
Microboards' New DX-1 Disc Publisher to Ship Microboards’ New Print & Burn DVD/CD Duplicator Ships
Industrial quality of DX-2 and Print Factory in a Compact Package with the DX-1
Chanhassen, MN, August 17, 2004 —Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
You've got an expensive unit (see below for Press Release), with a built-in CD/DVD reader/writer.
Given that your unit could be six years old, it's possible that the reader/writer has "died".
It seems to be a "stand-alone" unit -- not something that requires either Mac OSx or Windows XP/Vista/7 to operate.
I'm guessing that _ANY_ IDE (not 'SATA') HP-brand reader/writer, provided that it has a "LightScribe" capability, could be purchased, and could be inserted to replace the "dead" reader/writer. For about $100, it's worthwhile to try this "substitution" to revive your unit.
____________________________
Chanhassen, MN, August 17, 2004 — Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
Jun 10, 2010 | MicroBoards DX-1 Publisher Printer
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
CD/DVD Tray open; Close Tray to print
This solution is taken from the HP website.
Follow these steps to print on a CD or DVD.
  1. Make sure that the CD/DVD tray is completely closed (completely inserted into the product).
    NOTE: Make sure that the side of the tray that holds the CD/DVD is inserted into the printer first.
  2. In HP Photosmart Essential, click the Print tab.
  3. Click Printer Settings and then click Advanced to open the printer properties.
  4. In the properties, click the Features tab.
  5. In Paper Type , select Printable CD 120mm .
  6. In Source , select the CD/DVD tray .
  7. Save the settings and then again attempt to print on the CD or DVD.
Feb 05, 2009 | HP Photosmart D5360 InkJet Printer
I cannot copy pics or text to dvd
Assuming you have a DVD writer installed and functioning in your computer, check the format of your dvds. If you have a writer that uses dvd-rw it may not recognize dvd+r discs. Your label on the dvd package should have the disc format and your documentation for the writer should say what formats will work in the writer.
Dec 31, 2008 | E-Machines eMachines Desktop PC
Why Can't I get my computer to print Lightscribe labels
Try going to www.lightscribe.com and using their program. It works really well for me
Dec 23, 2008 | HP LightScribe dvd640i (DVD640I)...
Canon PIXMAiP4500 printer
Select the print dvd/cd cover application, when it opens it shows the outline of the label
Select 'text' and type your text, then adapt it by font, style, size and positioning.
Can preview on the label and drag it around like a text box in MS Word
For images, select 'insert' from the menu on the screen, browse to your phots and select one, then accept it and preview/resize on the label shown on the screen
Then select 'print'
Get your cd hol;der ready, open the front of the printer, then open the flap with 'Canon' on it
Wait foir screen prompt to insert the holder, with the cd upwards facing and at the end nearest the printer
When prompted, insert it so the 'arrows' on the left and right are flush with the front edge of the flap you just folded down
Jun 01, 2008 | Canon iP4500 Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
126 people viewed this question
old marine
old marine
