we downloaded music files onto our player, but when we try to play them. it say no files...when we hook it up to the computer the files are there...can you help
Comments:
Feb 10, 2008
- the player s set at wav and not mp3, does anyone know how to change it t mp3????
-   I dowmloaded the files to the player and it says files do not exsist, but when plugged into the computer it says the do exsist. How do I fix this?-   Ber92
Feb 15, 2008
-   how do i get my mp4 player to work-   Guest
Here is the answer. The problem is the software that the MP3 Player runs off of. It can only read so many file directories, once you have too many file directories, it just stops seeing them. You have to try and cut down the number of folders you have. What I did with mine was took them out of the sub-folders and had all the music under the artists name....you'll just have to **** it up on this one, bad R&D, but you went with an inexpensive MP3 Player....you get what you pay for.
My theory: The real problem is they stuck the firmware for a 1 gig player into a 2 gig player and a 4 gig player. So the file-size limit is hard coded. Reach 1gb of files and anything after that is unrecognized... either because of limited RAM space on the system-on-a-chip OR when they designed the player when 1 gig was the highest available. They never bothered to change the firmware for higher capacities!
Same problem as others. Does not turn on unless the USB cable is connected. Says Version 2.620.105...
(More)
Same problem as others. Does not turn on unless the USB cable is connected. Says Version 2.620.105 as the software version.
need to know how to use this anko mp3, mp4 player...very basic use..like how to play? when it comes...
(More)
need to know how to use this anko mp3, mp4 player...very basic use..like how to play? when it comes on and I push play it turns back off??
Well i don't think this is a ? but i don't know what kind of headphones i need to buy cause mine are...
(More)
Well i don't think this is a ? but i don't know what kind of headphones i need to buy cause mine are broken right by the jack...maybe its still under warranty...and if u could send me new ones...dat would b awesum!! i also don't know what a wma is... or how to delete songs you dont want any more... plz help!!
